Procharger Stage 2 Install
TwinTurboMustang.net
San Diego, CA
Noah
2015 Mustang GT PP
This is probably more likely to happen as boost increases. I think that piece should re designed by ProCharger.
D3adch1ld
Blabber Mouth
New York
Marcos
15 Mustang GT Premum w/ Performance Pack
Agreed, it could also have to do with the airfilter element not being breathable enough. I'd look into turbo specific filters.
5.0 Steve
Albany, NY
2015 GT
Look at all the other intakes their either aluminum, plastic, or carbon fiber not silicone hose
gqneon
Westfield, IN
18 GT PP / Manual
I'm looking at mine to see if I can replace it with metal or something solid. Anything flexible and under vacuum can be weak at a bend. Even if it isn't doing it now it can weaken over time. I'd sure love to see that 3.75" hose for the inlet that fits properly instead of the .25" too small one they say is good enough. I want to pop offer my inlet hose to try some alternatives but I'm not sure I can get it back on without another ww3 and I don't need to be without a car if something comes up once I do it. I took a lot of pictures, and I think a filter right on the inlet with a t for the pcv inlet would eliminate that completely. I'm afraid to vent my pcv or cap it off after Phil's ordeal, even though a lot of 2011-14 guys have done so over the years.
Tapatalk spelling errors inside!
Phils15GT
Albany, NY
There are a few guys running with the breathers and IMRC vent line unplugged/just venting without issue. I drove the car when I picked it up from the shop on friday. I have the IMRC unplugged which is keeping it open all the time. Car drives normal but obviously its not hooked up the proper way and throws the IMRC code. But... the thing moved out. Wish I could have figured it out..
D3adch1ld
Blabber Mouth
New York
Marcos
Hey Noah, what kind of numbers did you get to most recently. Saw the Vlog and your car looks like a monster. Lots more torque than I would've guessed
gqneon
Westfield, IN
18 GT PP / Manual
What kind of torque you getting?
z06psi
Evans, GA.
Andrew
The pot stirrer
I have an idea for this hose collapsing problem. PC will take at least a month or more even if they decided to fix it. They might not.
gqneon
Westfield, IN
18 GT PP / Manual
No filter.
Nemesys
United States
Oxford White S550
Im having the same surge issue under load and part throttle. I also sent a PM to Prochargertech about some issues I had with install and some parts that seem to be incorrect for my kit.
Process
Pittsburgh, PA
2016 Porsche 911 Turbo S & 2016 Shelby GT350R
Myself and a buddy had to create a new inlet tube as the one provided does not fit. Something made out of plastic would be best or just a filter.
Nemesys
United States
Oxford White S550
Can anyone tell me if this sounds fairly normal ? Not sure if that bearing/grinding noise in the background behind the procharger whine is normal. Just want to make sure as my Novi2200 wasnt this loud, but I love how loud this one is lol
[ame]
SHFTN6
Belleville, il
Tyler
2015 Premium GT Performance Pack
Mine makes the same noise. I wondered the same thing especially because I bought my kit used.
