Procharger Red Race BOV
BBW P1X
Arizona
15 Mustang GT
I just installed a PC red race BOV, lets say installation is a PITA, however, i had the PROFLOW BOV is the RED RACE meant to be open? i turned the car on and it doesnt close during idle?
Cory S
Bradford, NH
Cory
2016 Mustang GT Premium
Yes. Vacuum keeps it open until boost......and they are annoying loud while cruising at RPM above 2500...
BBW P1X
BBW P1X
Arizona
15 Mustang GT
okay good and so under boost it will close, and once i release the gas it'll reopen correct?
Cory S
Bradford, NH
Cory
BBW P1X
BBW P1X
Arizona
15 Mustang GT
alright well i think something might be off, the car doesnt want to go into boost, the only other time i ever had this issue was because one of the couplers blew off, as per this BOV im assuming that it isnt closing, i left the same sized vacuum line that my proflow had which i think is 1/8th vacuum line. Would that be the issue?
Cory S
Bradford, NH
Cory
Maybe it’s pinched? I do think for best valve operation on those is when using 3/16-1/4” vacuum line though. Watch the valve if you can while someone whacks the throttle abruptly from idle to 4000rpm. You should see it immediately slap itself closed for a a second when operating properly.
andrewtac
TX
mark
F250. 2020 GT 400A
Or hook up a line a pull some vacuum on it to watch it open then pressure to watch it close.
BBW P1X
BBW P1X
Arizona
15 Mustang GT
okay im going to give that a try and its not pinched im abou 99% on that, im going to change the line today to 1/4th since the fitting is 1/4th and i will go ahead and give that a try
Cory S
Bradford, NH
Cory
1/8” Could be collapsing. Hmm.
Leonidas514
Oviedo, FL
Chad
2015 GT
In my experience the BOV needs a good vacuum reference. I had the same issue but went back to my old setup and it fixed the issue.
BBW P1X
BBW P1X
Arizona
15 Mustang GT
yeah, i bought bigger vacuum fittings and bigger vacuum line and it works perfectly now. it actually closes as well as it goes into boost now.
Jackson1320
California
Jaxson
2015 mustang gt
Nothing wrong with the big red but you can get a tial cheaper and for $50 you can get a eBay bov and it works just as good
BBW P1X
BBW P1X
Arizona
15 Mustang GT
i got it for free from a buddy since he totaled his truck, if not, tial would have been my first option
