The brackets are identical but mirrored. Seems sturdy enough for now with the 3 bolts.Are the brackets identical? I can't remember.
I almost wonder if the person assembling the intercooler didn't "measure twice and cut once" when he went to weld in the tubes for those bolt threads.
I wouldn't have a problem with just 3 bolts for the time being. You could always drill out the bracket a bit..The brackets are identical but mirrored. Seems sturdy enough for now with the 3 bolts.
Procharger is taking care of it. However, any tips on getting that damn 90 on? It does not fit! I've seen countless people say it's too small, guess what? It's too small!I wouldn't have a problem with just 3 bolts for the time being. You could always drill out the bracket a bit..
Yeah that's the one I'm using. It's also alot more rigid than the othersUse the 3 bolts for now, it will be MORE then secure.
As for the 90, make sure you are using the correct one, in the correct place.
One is slightly larger then the other.
If you have a newer kit, the one going on the blower is dull, not shiny
