Procharger install help!!!
r1lovin
colorado
2015 Gt
H.o. intercooler but the driver side mount doesn't line up?? The passenger side lined up fine. Am I missing something or is it the bracket? Is it the intercooler?
[/URL][/IMG]
michigan stang
Eaton Rapids Mi
Shawn
65 coupe, 2015 gt pp stg 2 procharged
Looks like from the picture the bracket is wrong. Call procharger. They are great to work with.
smokinzx14r
ST Petersburg FL
Lee
2015 GT A6 3.55 Gears ..
Hope they send me the right one ....
sanchezcruz_20
Columbus, OH
2015 Ford Mustang GT
Are the brackets identical? I can't remember.
I almost wonder if the person assembling the intercooler didn't "measure twice and cut once" when he went to weld in the tubes for those bolt threads.
r1lovin
r1lovin
colorado
2015 Gt
r1lovin
r1lovin
colorado
2015 Gt
The brackets are identical but mirrored. Seems sturdy enough for now with the 3 bolts.
sanchezcruz_20
Columbus, OH
I wouldn't have a problem with just 3 bolts for the time being. You could always drill out the bracket a bit..
r1lovin
r1lovin
colorado
2015 Gt
Procharger is taking care of it. However, any tips on getting that damn 90 on? It does not fit! I've seen countless people say it's too small, guess what? It's too small!
15GTPP
El Paso
2019 GT
Ask for the updated 90 since they are sending you a bracket anyways. Goes on a lot easier.
ProChargerTECH
Boostville
2015 Mustang(s)
Use the 3 bolts for now, it will be MORE then secure. :)
As for the 90, make sure you are using the correct one, in the correct place.
One is slightly larger then the other.
If you have a newer kit, the one going on the blower is dull, not shiny
r1lovin
r1lovin
colorado
2015 Gt
Yeah that's the one I'm using. It's also alot more rigid than the others
