Prepping for E85 - Personal Experience on Switching
BigLo
Kentucky
Logan
2018 Mustang GT - 6MT
I am planning on getting an E85 tune in the spring once the weather warms up. I have seen contradicting discussions on what is needed/suggested to run E85.
I know gen 3's don't necessarily need any supporting mods to run E85, other than a tune that is. I am just wanting to hear yalls personal experience with E85 with this platform and what you have done (or been suggested to do) to get the most performance and reliability out of running the different fuel.
For reference, I have a 2018 GT.
TonyT930
Philadelphia, Pa.
Tony
2017 Mustang GT Convertible in Ruby Red
Well beware, E85 is going to attract a lot of moisture. I would use a small maintenance dose of dry gas to help with that. Just a thought
robvas
MI
2011 GT
You want to add alcohol to gas that's already 85% alcohol?
Jeepwx03
PA
68 Mustang, 15 Mustang GT PP, 13 F150 FX4
Ive been using e85 for a couple years with no issue, Ive heard that keeping the tank full if the car will sit for an extended period helps with the moisture build up, so Ibe done that and haven't had issues.
I have an inline sensor and a gauge that measures the ethanol content, Ive learned which local stations usually have higher results this way without needing g to have the manual tester.
I like the smell of the exhaust more as well 😋
RNM
2022 Mustang GT
If you are going to be running E85 on your daily, be sure to change oil more frequently (every 3k instead of 5k) especially if you drive short distances.
NightmareMoon
2016 Mustang GT PP w/ Voodoo
Yeah, just increase the oil change intervals, and figure out where the good E85 (actual 85%) is in your area, with the low energy density and therefore fuel mileage of E85 you're going to be at those stations a lot.
My coyote loved the stuff. Ran great on it.
robvas
MI
2011 GT
5K? people are going by the OLM so they aren't changing it until well past that
slowgo50
michigan
jacob
2019 mustang 5.0
Going to butt in, my car was tuned on the dyno. If I want to switch to 85, do I take it back to a dyno, or how should I have it tuned?
slowgo50
michigan
jacob
2019 mustang 5.0
No need to tune it on a dyno.
What’s everyone using for a tuner then? New to the Mustang world. Bought at 19 with a procharger recently, still trying to figure everything out.
BigLo
BigLo
Kentucky
Logan
I'm using a SCT X4. Most tuners use that, HP Tuners RTD, RTD+, MPVI2, and/or AVID.
As far as tuners go there are a lot of companies that can make and send you a tune you can flash from the device itself. Some for example are Lund, Shoemaker, Wengerd, PBD.
slowgo50
michigan
jacob
2019 mustang 5.0
And they’re decent? Would I be going backwards, if I have to delete my tune from the dyno, and went with a company that sends me a tune?
BigLo
BigLo
Kentucky
Logan
Short answer is yes, a new tune file would replace what you have now.
Would you be going backward? That's subjective.
If you are already dyno tuned for pump gas (i.e. 93), then I probably wouldn't seek out another 93 tune from a different tuner unless you are unhappy with the results of your current config.
But if you wanted to go E85, then they would send you a E85 file that you would flash to the car.
The good thing is when you connect a device such as the SCT, it stores whatever is written in your car at the time of pairing as the "base tune". So you'll have it whenever you want to revert back to what tune your car is currently running on.
