PP Wheels in the winter?
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
or you can go with something like the Groundforce GF9 19x9.5 square fitment, deep concave and cut on order for the best fitment !
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Renner
Huntley, IL
2016 GT SOLD-2015 Ecoboost SOLD
could you run 245/40r19 on 19x9.5 sve drifts without too much stretch?
Yes you can get them on...personally I would use 255 though
willmkent
'Twas sure good see'in ya
Michigan
Will
2015 Ecoboost PP
Renner
Huntley, IL
Renner
Huntley, IL
Burger2002
Twin Cities area, MN
Ben
2016 GT Premium PP
Let me guess, you want the Michelin pilot Alpin pa4s
http://www.tirerack.com/tires/tires...l=Pilot+Alpin+PA4&partnum=44VR9PA4XL&i1_Qty=4
I do too. Seems like a killer deal.
My only concern is the diameter difference. Using some online calculators, it seems that 245/45 19s are closer to stock overall. The factory staggered setup makes it hard to know which tire we should be trying to size match when switching to a squared setup.
Can anyone confirm that 245/40 19s will work on all 4 corners without creating a major speedometer issue? I'd like to do that on 4 factory front PP wheels.
Cloak
Northern VA
www.instagram.com
2019 Shelby GT350R Shadow Black
those are the ones. reviews just as good as blizzack lm-32
the stock performance pack diameters are 27" front, 27.7" rear. You are supposed to calibrate to the driving wheels (rear), but I don't think doing 27" all around would make much of a difference. it will throw off the speedo by about 2mph at 60+
the pilot aplin in 245/40r19 diameter is about 26.8"
Renner
Huntley, IL
there wouldn't be any major speedometer issue...maybe 1-3mph max. The issue with 245 is they are not recommended for 9.5" wheel.
Renner
Huntley, IL
rainier446
Professional Amateur Tech
NoVA/MD/DC
Shawn
'15 OW GT/PP
most 18" wheels wont clear the GT PP wheels you will need a rotory forged wheel or flow formed wheel so for 18" you need
Forgestar CF5
HRE FF15
MRR FS01 ( being test fitted soon)
a better solution would be a 19" wheel with a winter tire something like the Blizzak LM-32 tire is my recommendation.
Im more then down to help you out if youd like.
A good cost effective route is to use your GT PP wheels pair that with a winter tire for the winter season and grab yourself a set of wheels for the summer season, something that will also help shed unsprung weight which is a big benefit.
Not to detract from the OP's subject but, 18" CF5's will fit the PP brakes???? :eyebulge:
