Powertrain Malfunction/Reduced Power
Sparky75
Southwest Michigan
Jeremy
2021 GT500, 2012 F350, 2020 EXPLORER ST
I keep getting this message along with the wrench light. I took the car to the dealer, 21 GT500, and the codes were P2781 and P2777. They are for downshift circuit high and upshift switch circuit high. They couldn't find anything wrong but did a ECM & TCM update. I didn't make it 5 miles from the dealership and the first time I got on it the wrench light pops back up and I get the same message in Ford Pass. Has anyone else had this happen? if so, what ended up being the problem. I am hoping to find a direction to send them in.
Jmeo
You said member ;)
Massachusetts
Jaime
2020 GT500, 2023 F150 Raptor
Have you changed your steering wheel? I have seen similar issues when a harness wire gets pinched during the re-install. The issue can be immediate or some time after.
Sparky75
Southwest Michigan
Jeremy
As a follow up to my original post, the issue ended up being the SCCM (steering column control module). Hopefully if someone else has this issue in the future this will point them in the right direction.
