Plus sized Speedometer Adjustment
Greek6486
@Gt_supercharged
Hi all,
Anyone had to adjust your speedometer to after getting larger diameter tires? I'm about to be running 285/35/20 fronts and 315/35/20 rears. My tuner said that they aren't able to adjust the 2016 speedometer threw the tune and said I have to use some program called Forscan. Anyone dealt with this?
Thanks!
Greek6486
Greek6486
@Gt_supercharged
Nobody knows anything about this? lol.... Does everyone just not care about the speedo?
msweet
Sydney
2019 Ruby GT PP 10A w/ Magride, Recaros
Look at the "asbuilt" thread in DIY.
I'm running 315/35r20 and did adjust it through Forscan, but it messed something else up. It was almost like a limiter at certain revs in different gears. I went through everything that I had adjusted and found that one line change to be the issue, YMMV.
Suffice to say I changed it back and now just drive a few ks under the speed limit past speed cameras etc
stang1971
kcmo
2018 Premium Plus Magnetic GT
I am on a 315/35/20 in rear and changed mine with Forscan an d its almost perfect. I have no side effects and the car pulls hard in every gear.
ahl395
Allan
You can also use a Whipple Flare Tool to correct the speedometer
webelevy
No. VA
2016 GT Premium, Ingot Silver,Recaros, 20in Foundr
SR56
Orlando, FL
seanrooney.realtor
Sean
2016 GT PP
dgc333
MA
15 Mustang Ecoboost Premium
The Ford ProCal software allows you to make adjustments for gears/tire size.
