OppoLock
RWD Addict
- Apr 21, 2014
- St. Petersburg, FL
- Sean
- '15 GT, '20 GT350
- Vehicle Showcase
- 1
I tried both ways. I have no idea how you guys can use the upright rolling technique unless your foot is shaped like a ping pong paddle... I'm wearing wide Ecco dress shoes more often than not and I just can't get anything going. :(It is true that heel-toe in this car is easier under harder braking. But at the track obviously this would be a non-issue.
There are two ways to heel-toe: (i) have the left side of the ball of your foot on the brake and roll your foot on an axis parallel with the long axis of your foot to blip the throttle with the right side of the ball of your foot (or just below). Your heel may or may not rest on the floor. This works if your feet/shoes are wide enough, but won't work if you have narrow shoes (like Piloti's, Sparco's, or Puma driving shoes) or if the pedals are too far apart (either width or depth). (ii) the second method, which seems to work better in cars with top-hinged accelerators, is to plant the ball of your foot square on the brake pedal, then swing your ankle on an axis parallel to your shin and centred on the ball of your foot, and blip the throttle with the side of your foot or even down closer to the heel. I find this second method works great on the Mustang, and I find I can have better control of throttle blipping and a lot more stable connection between my foot and the brake pedal (which is the most important thing, street or track). I will use both methods in my Mustang, depending on how hard I am braking and what shoes/boots I am wearing (real Canadians can heel-toe in mukluks).
Here is a vid of a fine driver in an RX-8, which I was driving at the time I found the vid and learned the technique.
This hasn't been an issue in past cars I've driven either.
