So ordered the pcv breather kit from lmr. Comes with 2 filters and 2 vac caps. Not no instructions. I have a procharger setup so does anyone know what hoses to remove and what to cap?
LOL, pcv lines are the ones that come off your cylinder valve covers, remove the lines/ hoses that go from the cover to the intake manifold. Caps go on intake manifold and the filters go on the pcv valve on the right side of the motor and the inlet breather on the left side of the motor. I'll look for a pic to link.
I know what pcv lines are. The only place to put vac caps with procharger is where the imrc line comes out. However i dont believe that should be capped
The line for the imrc is just a vent so just l eave the line coming from the imrc uncapped.Also.when u put the filters on the one the pass side is your pvc,make sure u take the little ball and spring out of it so it vents all the time,otherwise the pvc will stay closed amd not vent on that side.
