Crankcase Breather Filters
Joe 5.0
Bermuda Triangle
2015 Mustang GT/PP
Is it beneficial to install two crankcase breathers on my FBO N/A 5.0? That way, nothing can gum up the intake manifold and throttle body. I already have a JLT 1.0 catch can on the passenger side, but I'd replace that with a filter.
Also, would it have any detrimental effects on the motor and/or emissions monitors?
I'm essentially done with mods with the season, so I figured I'd do what I can to improve my motor.
kent0464
Virginia
Kent
1983 Ford Ranger, 1986 SVO Mustang, 2017 Mustang GT PP, 2017 F150 3.5 Eco
I was going to put a catch can on each side, but guys I’ve talked to that have done it say that while the passenger side catch’s quite a bit the drivers side catches absolutely nothing, so doesn’t seem worth while. So just a filter on the passenger side would probably be a bad idea, as far as putting a filter on the drivers side I have no idea what that would do, maybe a massive vacuum leak idk.
1MEAN18
Where I stand
'18 GT
Just one needed on an n/a, it does help up top on the rpm's. A CFM one, or anyone with the one way ball valve inside and breather placed on the passenger side is only one you need...like the catch cans, anything on the drivers side is a waste of money and time.
Joe 5.0
Joe 5.0
Bermuda Triangle
2015 Mustang GT/PP
So you’d put the breather on the passenger PCV valve and cap off the intake manifold nipple?
1MEAN18
Where I stand
'18 GT
No. Check out the UPR breather that replaces the oil cap on the passenger side valve cover. That's all ya need.
Zinc03svt
usa
stang
That one does not keep oil out of intake. Pop the check valve out of passenger pcv. Cap off nipple and add your 10 dollar filter. Simple, easy, effective.
1MEAN18
Where I stand
'18 GT
Nobody said they keep oil out of the intake, they are not used for that, a catch can is used to do that job. A breather is only used to relieve crankcase pressure/blow by to keep the rings from rattling at high rpm's. And on the coyote I'd only put a breather on the passenger side, anything placed on the drivers side is a total waste of time and money on a n/a engine.
Zinc03svt
usa
stang
Why not do both...? No need for catch. lol
1MEAN18
Where I stand
'18 GT
You still need a catch can on the passenger side too. All DI engines do, some more than others. My Ecoboost engines actually catch way more oil than the catch can on my coyote, because the Ecoboost is boosted...but I do catch a small amount of oil in the one of my 5.0 L...but its not much. I had one on the drivers side for approx 1k miles, the inside of the catch can was bone dry, so I took it off and re-sold it. On an n/a coyote, nothing is needed on the drivers side at all...
