Partial cradle alignment sleeves
JOKER M1
Somewhere in Indiana
2015 GT Premium (SOLD)
At one point I was struggling with getting the sleeves in place, so I called BMR and discussed my situation. The gentleman told me it wasn’t the end of the world if I only got 3 in. He said it’s a Ford, not a high end German car, tolerances aren’t in the same league.
Fortunately I got back to it and got all 4 in place.
I’ll be doing a few more suspension parts which is why I’m gonna give it a go, hopefully there will be enough slop/play/give to get it done.
GTP
Deutsche Pony
Indy
www.BambergAudio.com
Philip
Leveraging the cradle around with a long 3/8" extension inserted into the body pry hole will help you a lot.
GTP
Deutsche Pony
Indy
Philip
The other option is to pull all of the cradle bolts and pull the cradle rearward to get space with the gas tank.
Yeah, but that won't help with Doug's CF driveshaft!
DougS550
Fishers, Indiana
Doug
Removing the rear CF DS bolts isn't hard. I cut down a 3/8 drive allen head socket to 3/8" which makes the job very easy to remove, install and torque. I wont put any strain on the shaft, just to many variables.
vinny89gt
VA
LaFlamaBlanca
2023 Iconic Silver GT PP
I heard that the CB005 does a good job centering and so you don’t need the centering sleeves…
@BMR Suspension?
Before I purchased my CB005 I called and asked if the SCB766 were a good idea to do at the same time. BMR told me that they were not necessary. On their own yes, with the CB005, no.
Robottrainer
Canada
2018 Ford Escape. 2020 Jeep Cherokee. 2021 Ford Mustang GT Stage 2 Roush
I would disconnect the driveshaft regardless. Too much risk fubaring a 2000 dollar drive shaft.
DougS550
Fishers, Indiana
Doug
I wont FUBR my CF DS. I plan to buy FP half shafts or equivalent, replace bushins, install Studs and switch to E85 possibly with KPM 1500 with PWM control returnless fuel.
Robottrainer
Canada
I have the FP half shafts. They are actually G Force half shafts. The only thing is the boots are bigger than stock and they get really close to the shock. They actually contact the shocks when hanging unloaded loaded there is about 1/16 to 1/8 clearance.
DougS550
Fishers, Indiana
Doug
Wow, are the GForce any tighter?. I just mounted my Toyo R888R 325/30/19 tonight. Their is about .200 clearance between the top of the tire and my Magneride Shock.
Robottrainer
Canada
Yeah, I think with the big tire some are going with a different top shock mount to gain more clearance.
DougS550
Fishers, Indiana
Doug
Does some one make a different top magneride shock end?. I know it will be just fine, but when I have the rear tires off again I will grind the ends down. Structurally will not hurt them. Later
Robottrainer
Canada
J&M makes a low profile steel mount.
