Painting the CAI ?
Slow.0
Ft. Lauderdale, Florida
Cedric
2019 Mustang GT350
I bought a used S550 and the previous owner put a chrome BBK intake. Although i like the actual intake i dont like the chrome affect in the engine bay. Is it safe to paint the intake to a different color? Preferably black. If so, what type of paint would i use?
StoplightWarrior
Bay Area, CA
2017 STi, 2016 Camaro SS, 2016 Infiniti QX50
could you plastidip it?
aham23
FPC 5.2
Phoenix
22 FJG Mach 1 w/ HP
VHT Engine Enamel spray paint from Autozone or most auto parts stores.
Clean it, apply the primer, let dry, apply the coats of color, let it dry, apply the clear gloss over the top to finish it off.
I painted my plastic engine covers with no issue.
Slow.0
Slow.0
Cedric
2019 Mustang GT350
I was thinking plasti until i thought of the heat. But i will try that VHT engine spray. Havent seen it before but i will look for it. Does it have a special primer?
Coconut
Poptart
San Jose, CA
Aaron
2016 Mustang GT Magnetic manual
Any high temp engine spray should do. Maybe try a wrinkle black finish? Or do it right and get it powdercoated. Shouldn't be that much, maybe $50-100?
aham23
FPC 5.2
Phoenix
22 FJG Mach 1 w/ HP
Yeah VHT makes the primer, paint, and clear gloss.
Southview
Viera, FL
Herby
2015 GT Premium Convertible
Plasti dip will be fine. If you want to paint it. You will need to rough that chrome up with 180grit. Then use an etching primer before any regular primercan go on. You can go straight to sandable primer but the paint can flake off the chrome easy if you nick it during install.
My recommendation is to plasti dip, no prep other than make sure it is clean. Add a glossifier if you want more shine or powdercoat it.
If you go the paint option, you will have half of what it cost to powder coat it. If you go plastidip you will have $15 into it.
Dsquared
Northern NJ
2017 GT PP LB
^ what Southview says. Most important factor is good prep. Don't shortcut it.
