P2254 error code. 2016 gt LTH help
diegocarvallo89
Conover, NC
Diego
Mustang 2016 GT DIB
Hey my set up is long tube headers off road with cords sport exhaust.
I tuned the car and have been driving it for 9 months and no issues .
Last night we installed an amplifier and subwoofer and a check engine light came on... I used my scan tool
And it gave me a p2254 code 02 sensor negative current control circuit / open bank 2 sensor 1
What could be the cause of this? Did I fry a sensor? Any help is really appreciated
Thanks a lot
Diego
2015 Silver GT
East Haven Connecticut
2015 Ingot Silver GT Premium
Sounds like you have a front sensor that has gone bad. It's pretty common if the o2's are at the 9:00 and 3:00 position and more so if running E85.
diegocarvallo89
Conover, NC
Diego
Mustang 2016 GT DIB
Hey!
I am still running premium fuel. Where do I get this sensor to replace it?
Shnuggles
Columbia, SC
Brandon
2016 Mustang GT/CS
I'm running into this same issue, did you ever fix yours? I've already replaced the O2 sensor it says is bad, exact same one as yours, P2254. I've also replaced O2 extensions, no fix yet :/
NGOT8R
Adrian
2019 Bullitt
Could also be a bad o2 sensor extension harness.
Shnuggles
Columbia, SC
Brandon
2016 Mustang GT/CS
If I replaced the O2 Extension wouldn't that be the harness? Or is there something else I need to buy for the extension harness? And if so can you link me to one please for a 16 Mustang GT? I've already replaced the O2 Extensions though if that's what you mean.
Cordero1
Kansas
Vic
2021 Mustang
Guy hasn't logged in for a long time & thread is years old
NGOT8R
Adrian
2019 Bullitt
Can you remove the o2 sensor harness and check the wires with a multimeter to make sure there’s no break in any of them? I replaced my extension harness with a Kooks harness.
https://www.mustang6g.com/forums/threads/ntk-27063.189112/#post-3798192
Did you use new OEM o2 sensors? I tried generic ones and my car wouldn’t run. I put in new OEM sensors and the car fired right up without any issues.
Shnuggles
Columbia, SC
Brandon
2016 Mustang GT/CS
Yes I used an OEM O2 Sensor. The extension I used as a replacement was the BBK O2 Extensions
NGOT8R
Adrian
2019 Bullitt
Just confirming, you replaced the o2 sensor on the driver’s side correct? That’s the bank 2 sensor. Did you make sure not to get any anti-seize on the sensor tip during installation?
Shnuggles
Columbia, SC
Brandon
2016 Mustang GT/CS
Correct, yes the driver side O2 was the one replaced. Idk about anti seize but that's only because I'm not familiar with what you're talking about on that.
