Crackerjack17
- Sep 22, 2016
- WV/Maryland
- 2017 GT PP
*** update ***
So I wanted to post this here in case anyone else searches for this and/or has this problem. After loading the procharger tune (not that I think it has anything to do with procharger, just a custom tune in general) the car was throwing the crank relearn code. I couldn't get it to clear, ford dealer couldn't either. So I purchased an X4 programmer, so I could clear code myself. Here is what I had to end up doing.... reinstalled factory injectors, removed supercharger belt, pulled maf from intercooler and reinstalled factory intake tube, and reloaded factory tune. Started the car, let it warm and then followed the crank relearn instructions in the X4. revved to 4100k, one time and it cleared!
So now I have to put everything back, reload the tune and see what happens.
Original post...
Did my opg, cs, etc,.etc. started car which had lund tune via ngauge. Ran fine no problems. Drove it a couple days, no CEL! Installed procharger, loaded tune from their ngauge, car started right up. CEL on. P0315. No biggie, friend has snap on solus pro, which does crank relearn. Can't get it to clear, so I'm like f'it. Drove to ford dealer after work today. Tech cannot get it to clear with IDS tool either. $90 down drain. Now what????
1. Unhook battery for a while?
2. Disconnect procharger, throw factory injectors in and start on factory tune and try to clear?
3. Don't worry about it and drive it like I stole it?
I've already loaded and unload tune, started it on factory tune even with procharger and tried.(but wasn't running very good) Nothing. Wth? Car runs strong. Numbers look good. A couple degrees positive knock at times, but I'm guessing shitty winter gas.
Original post...
