P0050 Code (02 Heater Circuit)
Ls_Eater
Apollo Beach
Parker
2018 Magnetic Metallic GT
Recently started getting a P0050 Code which references the Bank 2, Sensor 1, Heater Circuit is bad.
I would assume that if the 02 was bad my AFR would not read at all, and would cause some issues with drive-ability, however the car drives just fine, and AFR is reading appropriately.
From what I can see the Heater circuit is just that...a heater for colder climates to bring the 02 up to temp, living in Florida and seeing next to zero cold weather, I believe my 02 is still functioning perfectly.
Anyone else run into this? Simple as replacing the 02?
(Note I have cleared the code, and it goes away for the day, then comes back).
Grimace427
NoVA
2011 Mustang 5.0
The heater circuit isn't for cold climates as there is no climate on Earth that operates at the temps that an O2 sensor does(approx 700-1,000 degrees F) lol.
The heater circuit can fail and the sensor still operate but it will take longer to get up to operating temp thus causing the PCM to take a little longer to get into closed loop. I suggest getting it replaced soon.
Ls_Eater
Ls_Eater
Apollo Beach
Parker
Makes sense, hadn't considered the Temp's that it would be required to get up too.
Appreciate the Insight.
RBELUN
TEXAS
2018 GT P1
were wire extensions used in your setup? I'm replacing with a third sensor within 10k miles on car with Kooks headers....Mine has an extension on the bank and wonder if that may be the issue I'm having.
10SpeedDemon
Atlanta, GA
www.instagram.com
Dre
2018 Mustang GT A10
I’m having this now.. I cleared the code but it comes back after a couple of months. Should I replace the extension or sensor
Andy13186
Are you guys on e85, or burble tunes by chance? My sensors have died a few times usually after running e85 or crackle tunes.
Bmaughan
Az
Ben
2015 procharged mustang gt
Just had a sensor fail.. same issue with the heater failing but on bank one... just threw a new sensor in..all good now. On e85 for only 1k miles
RBELUN
TEXAS
2018 GT P1
E85 for 5000miles after fixing my HF cats that were collapsed. Also made my own extension from Combination old sensor wire and new sensor. PBD tune. Kooks headers. No more codes. Thank The mustang gods.
10SpeedDemon
Atlanta, GA
www.instagram.com
Dre
2018 Mustang GT A10
What side o
Driver or passenger side for this code?
Bmaughan
Az
Ben
which sensor is p0030? i get that sometimes and clear it out
That is bank 1 sensor 1 (passenger, pre-cat)02 sensor heater element
