Burnin4
- Apr 6, 2015
- Mooresville
- 17 GT350
Your setup has mid 11's at 120 potential, with the right 60ft/decent conditions. So much of the 60ft is controlled by the tune. I worked extensively with my tuner, started off cutting 1.7's, then 1.6's, then 1.5's, now 1.4's, auto/3.15, on the same set of 20" True Forged wheels with 305/35 ET Street II's, 16.5psi. I still have stock shocks and BMR Performance springs, not drag springs.
I've launched my auto setup every which way possible, all of my best 60's come from loading up the stock stall as much as it'll handle without pushing through my the brakes. Listen to my rpms in this first 60ft (1.49) in my vid. You also need to stage as shallow as possible, barely triggering the 2nd light, you want that 2nd light almost flickering, gives you a running start.
Auto + 3.55 + 28" tire is a great combo for bolt-ons, 3rd gear holds till 123mph/7900rpm
Auto + 3.15 + 28" tire is the best for FI, 3rd gear holds till 141mph/7900 rpm
This calculator is essential for calculating optimal trans/rear/tire/rpm combo's for the most effective et's/mph.
http://www.apexgarage.com/tech/gear_ratios.shtml
