Opg install, Whats all required?
Crackerjack17
WV/Maryland
2017 GT PP
Good job. Pretty easy fix but nice if it can be avoided.
Worst case scenario, I would have followed the engine re-assembly section. it details out how to position cams, etc. Now that I feel more comfortable with all this timing stuff, I think I'll go ahead and install the MMR tensioner mod. I have it, but after almost screwing up removing the timing chains in the right order, I was going to skip it. lol. Now it seems easy. Thanks for everybody's suggestions!
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Do yĂ´u have the instructions for removing the cam phasers? The short of it is, if you keep the cam gears and chain together when you slide them off you can just slide them back on in the same position. I marked the back of the phasers and cam before sliding them off to make it easy to line up when installing. Also make sure you hold the cams with a wrench when you go to loosen the bolts as not to move anything.
Crackerjack17
WV/Maryland
2017 GT PP
yeah, I have the full service manual. I was thinking same thing, just slide off assembly as whole and slide it right back on. Going to do it this evening.
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
Make some referrance marks on the cams and phasers for piece of mind. Good luck.
Crackerjack17
WV/Maryland
2017 GT PP
another question... I managed to squeeze the tensioner in upside down without removing the large cam cap, so technically I only need to remove the two inner bolts to install the mmr bracket, but common sense is telling me I should remove all four and re-torque as a unit? Or did you guys only remove the two inner bolts?
db252
Equinsu Ocha
Bay Area, CA
16 GT Premium/PP/Nav
That's one way of doing it and just torquing the two bolts would be fine. I removed the cap and put it together that way so I had to torque the four bolts.
Don't forget to put the top guide on. :)
Bartly
Out West
It's been a few days, I might as well ask a couple more questions.
How hard is it to torque the bolts holding the oil pickup tube? Seeing Rob's curved wrench makes me guess that getting a torque wrench in there is probably impossible. Once the bolts are started and most the way tightened, can you get a normal wrench on them for the final torque?
Secondly, my car is going to be down for a few days while I do it this, is there much of a concern or need/way to prime the pump and get oil throughout the engine prior to startup? Guessing I would take quite a few turns of the crank to really accomplish that, not even sure i could spin it fast enough. Is this worth doing?
Thanks again for all the help on this his topic!
Crackerjack17
WV/Maryland
2017 GT PP
You can't torque the oil pickup tube bolts, just have to snug them up nicely. It can't be that critical other than you don't want them loose, lol, there is an o-ring that seals it. I curved my wrench just slightly and was able to get the drivers side bolt tightened. It took about 15 minutes maybe to tighten it though. You can't move it much so it's slow going. I stuffed a plastic bag down into the oil pan a little to catch it if I dropped it. I used a magnet pickup to hold onto the washer and got it started with my fingers then put the wrench under it.
I don't know about how to properly prime, but I plan to leave the coil packs disconnected and turn the motor over a few times before actually starting.
FIVE_LITER
Indiana
16 GT PP Competition Orange
I didn't prime anything and had instant 90psi of oil pressure as soon as the motor fired up.
Bartly
Out West
Thanks again, lol.
Okay how about this. Hasn't been much talk of the crank gear (I went with TSS). Does it just slide on/off? Do I need a pulled for it?
Also, looking at my Boundary OPG set, I don't see a "this side forward" or anything like that. Does that mean I just set them in place and should be good to go?
db252
Equinsu Ocha
Bay Area, CA
Crank gear slides on and off and the timing mark is on the front. Don't put it on backwards.
The OPG can be put in either way.
Crackerjack17
WV/Maryland
2017 GT PP
What do you guys think about these torque to yield values on the front cover? Seems like overkill to torque to 18 ft/lbs then 60 degrees? It's a cover! When I turn them 60 degrees after torqueing, it seems like too much torque?? Especially since they are in aluminum. What do you guys think?
Roh92cp
Fort Kent Maine
Shawn
OW GTPP Whipple
I agree with you, it felt like wat too much pressure on aluminum threads. I did it anyway and nothing seemed to strip.
