HearThe Whine
So I’m waiting to receive my stage 2 edelbrock SC for my 18’ GT with the A10 and was doing some late night research and started to get into different failures when you get into big numbers. I’ve read stock parts should be fine till around the 700RWHP range. Then I’ve read that the oil pump gear is a for sure replacement. Then I’ve read it’s fine if you aren’t bouncing off the limiter like you’re racing in a video game. I’ve also seen conflicting numbers on when to start replacing the drive shaft and half shafts. I can easily be tuned to over 1100RWHP which is highly unnecessary. It’s not the horsepower of the engine itself that would cause failure of the shafts it would be the traction itself, right? That’s why prepped tracks and slicks are only a good idea with beefy rear ends since the stress comes from all the power having to really work to turn the wheels. With the upgrades I have planned I should be hovering around 850RWHP on E85 and I just want to see what experience other people have had. As well as what knowledge anyone can share, thanks in advance
(I also have a Shelby super snake widebody package which gives me 345 rears which will hopefully help with traction)
