Oil Pressure
MacSrc
Pa
Michael
2017 Jeep GC Altitude
Are you guys seeing high oil pressure on a cold start? Like 80+ psi?
What about idle once warm?
2015 GT Performance Pack
Yes, high oil PSI at cold start is completely normal.
Oil PSI will also vary and can be higher or lower depending on:
1) geographic location (colder or all seasonal climate changes vs. neutral/warmer)
2) drivetrain gearing and engine RPM due to transmission and rear diff type
3) oil viscosity
I’m in NJ, an ā€˜all season’ state; If I start up in the morning now with current temps in the 60’s and do normal acceleration, I’m seeing 100psi...
As the oil gets warmer, oil PSI upon acceleration is normally 80 PSI, while normal idle when hot (normal oil temp) is about 20-25PSI, and cruising between 60-65 mph is normally at 40-45PSI in 10th gear.
MacSrc
Pa
Michael
3) oil viscosity
Makes perfect sense. Thank you!!
