Oil Pressure Gauged Pinned...
ACMEguy
Calgary, Alberta
2021 Mach 1 FJG HP 'M3162'
Hi Everyone,
I haven't posted for a while. I have been waiting for my car to arrive and browsing the conversations that have been ongoing among the group. Well, my car finally arrived after 8 months! I brought it home from the dealer yesterday. It is going for full 3M Pro PPF and Ceramic tomorrow so it will be gone for another week! I did take it out for a short run today. Kept everything under 4,000 rpm and at the speed limit...
Trying to get to know the car and all of it's nuances but something struck me as unusual and I am hoping for some feedback and advice from the group. I noticed that the oil pressure gauge was max'd out, pinned all the way to the right for most of the drive today and my gut tells me that isn't normal... It is a 6 speed car, HP, loaded...
Once it's back I'll post some pics but by now it will just be another FJG HP Mach so nothing anyone hasn't seen already
Feedback appreciated...
Cheers,
WCRookie99
Illinois
G
2021 Mach 1, 2007 FR500C, 2022 LH5
M1 on start up, goes to 100psi until warm, then to around 70psi.
WCRookie99
Illinois
G
Check if they overfilled the oil, if not then you're right not normal.
Atlas1
Everett, WA
Congrats steve! And please post pics!
are you sure the gauge is working correctly? Does it show any movement at all or does it stay pinned to 100 psi?
I was nervous the first few times I drove my car seeing the oil pressure as high as it is. After doing some reading on here I learned that coyotes run high but it was definitely shocking to see at first.
Groovy
DFW Texas
2021 Mach 1 700A Tremec Oxford White
My Mach 1 runs WAY more oil pressure than my 2019 GT did.
murick
Prague, Czech Rep.
Richard
2021 Euro Mach 1, FJG, manual
If you can get the oil pressure in the digital cluster, could you check if the readings there are the same as on the gauge? Just to rule out a possible instrument malfunction.
ACMEguy
ACMEguy
Calgary, Alberta
Great idea! I'll change the electronic cluster to include oil pressure and compare on my drive the the PPF shop...
Atlas1
Everett, WA
@ACMEguy i drove the car this morning and tried to pay extra attention to the oil pressure gauge. For reference I haven’t driven it in a few weeks and it was 55 outside. It stayed pinned to 100 for a the first few minutes and until about 10 min when it was fully warmed up it didn’t move unless at idle. After that it came down noticeably. Depending on how short your drive is I could see where you wouldn’t get the needle very far off 100 psi
Mikepol2
Pittsburgh, PA
2021 Mach 1, 2019 Ram 1500
More importantly.... YOU HAVEN'T DRIVEN IT FOR A FEW WEEKS??!!
Atlas1
Everett, WA
I feel bad driving it to work because my commute is laughably short. The idle doesn’t even settle by the time I get there! Mike I told you, come out here and put a few miles on it!
Tshenberg
Independence KY
Thomas
2021 Mach 1 Chassis M1908
Hi Everyone,
Cheers,
I have HP, 6 speed, and yes oil pressure pins at start up, and I let it idle for a few minutes, and once RPM's come down, so does the oil pressure
S550VIN54
Raleigh NC
Stephen
2021 FJG Mach 1 HP
I wondering if this has something to do with the carry over parts (TB and intake)from the gt350. I remember my gt350 running high until it warmed up as well. I just figured it was the nature of the beast( voodoo FP crank) wanting to be unleashed.
Btw has anyone noticed any piston slap? Had that issue too.
