Oil Pressure Gauge
samd1351
Olathe, KS
Sam
2017 Mustang GT, 1999 Ranger
Quick question about the oil pressure gauge in '17 GT PP. What should the correct oil pressure be, and how much should it vary? I've noticed that it tends to be super high, 90 psi, when I first start the car. After about 5 minutes, it's holding steady at 80 psi under light throttle, and drops to about 30 psi as soon as I push in the clutch. It will generally settle in around 50-60 psi after 10 or 15 minutes of highway speed.
Is that normal? It seems like such a large swing for the first few minutes/miles.
Dweisman429
Jasper, IN
Daniel
Sounds perfectly normal.
As the oil gets warm it flows easier, thus the lower oil pressure.
And the pressure goes up when the room goes up.
Blue Moon
Maine, or eastern Canada
Pete
17 Ecoboost Perform Pack Std
Mine acts the same way. As oil warms up, it gets thinner and flows easier, so pressure drops. Totally normal, and it's a good reminder to not mash the go pedal to the floor before everything is warmed up.
Torched10
Atlanta
Bob
+1 on starting up slowly.i once totally disintegrated an oil filter on a 74 Pontiac superduty.what a mess in my driveway
samd1351
samd1351
Olathe, KS
Sam
That's what I waa thinking, just wanted to make sure. I usually take it easy until everything is warmed up. Just curious as to the extremes.
Thanks for the confirmation.
