Oil pressure gauge fluctuating
Rapid Red
Woodstock GA
Greg
I just did the first oil change on my Bullitt today. I also noticed a rather 'jumpy' oil pressure gauge. Prior to the oil change it seemed a lot smoother. Afterwards, it hovered 20-30 on light acceleration then it shot up to about 85psig at 4k. found it a bit odd and will continue to watch.
think the 20 quarts of oil had anything to do with it?
:crackup:
Only at start up, when bumps 100psi. <smiling>
GT Pony
Pacific NW
Wasn't really getting on it before that. So there's that.
Any RPM above an idle is going to make the oil pressure go higher. Typically about 10 PSI for every 1000 RPM on most engines.
engineermike
La
2018 GTPP A10
Are you all not understanding how the oil pressure control solenoid works?
NoVaGT
Northern Virginia
2019 PP1 GT Kona
engineermike
La
2018 GTPP A10
Cant speak for everybody else but I'm not there EngineerMike, Please explain.
There is an oil pressure control bypass valve controlled by the pcm. It will toggle oil pressure high to low and vice versa as a function of rpm and load. It does this stock and can be modified in the tune of desired.
