Oil line recall and oil change
Tomster
Beware of idiots
Tom
Its time for another oil change. I just did a 3 day track event and figured I'd change all the fluids.
To the point, they are going to loose a bunch of oil when they do this recall repair.
Now, I ask you to speculate..... Will the dealer do a complete oil change and replace the filter or will they just drop the filter and housing, replace the lines, reassemble, and then just top it up?
Why change the oil now if it will all be changed out very soon when the car is repaired under the recall?
Your inputs please.
CSL
WA
16 GT350
My intention is to insist on an oil change if that is not obvious to the dealer. Maybe I'm expecting too much?
mattlqx
Driver
Mesa, AZ
I'd be surprised if they don't drain all the oil to do the recall.
Regardless, the recall isn't going to be happening starting Jan 1. You'll most likely be near all the way through this next change interval before you can get it done. Change them now. I'm doing mine next weekend because I'll be right at 5k miles.
BlkGT3
Hot Spot
13 GT86 Autox, 16 GT350 TP, 06 Civic Si TTD car
I seriously doubt they will do a complete oil change. Just add a quart or so and call it a day. It is costing ford enough without adding another $150.00 or so for a full oil change with filter.
Peter
Epiphany
Global
I like to disassemble things.
I'm contemplating just paying for the part and doing it myself. Yes, it won't be properly documented at Ford. I don't need my splitter/bellypan screwed up a second time.
VOODOO 6G
Ohio
Eric
2016 Shelby GT350
That's what I'm doing.
KiLLeR2001
Orlando, FL
'89 240SX, '17 GT350
I'll probably remove the splitter at home before taking the car in for service, then reinstall splitter when I get the car back home.
Offboost
Sin City
2018 JR101 Kona Blue R Sold 1/21/19 New 2019;Ruby Red Raptor
I was thinking I would first remove the splitter and belly pan then take it to the dealer and let them change the lines. Then inspect everything they did and then reinstall the pan and splitter.
I think doing the line yourself could leave Ford a way out if you ever had a engine issue. Not sure its worth the risk, now if I had a tune or other items that have already voided my warranty then I would not let them touch it and would do it myself.
Tomster
Tomster
Beware of idiots
Tom
That is the way I'm going to handle it.
I will change the oil now. I'll remove the splitter and belly when it is to go in for service so that I can inspect the work. Reassemble it myself.
gww52
Eastern Pa
Guy
GT500
I got my new oil lines a few weeks ago.
They were produced on 9/6/16 and I'll install them at the next oil change.
I don't expect you will lose much more than a quart of oil.
jamesb1986
Los Angeles
James
2017 GT350
I plan on asking them to incorporate an oil change with the recall fix. I spoke to my dealer and they seemed open to working something out where I at least pay for the filter. If the dealer is due to handle the recall in Jan or Feb I should be at about 1800 miles or so and that would be perfect for my first change, plus only taking the car in one time would help.
Tomster
Tomster
Beware of idiots
Tom
I changed my oil yesterday and expected to see none of the sealant that I did last time. There was still a small amount at the bottom of the pan. I noticed some brass particles and am not overly concerned because it is still a very new engine. 2K miles. An oil sample was sent off to blackstone labs for analysis.
