Was looking for non ethanol gas last night and found this place.I may have to pick up some cans of 260GT this summer and give it a try
Probably starts high and dials back the knock until no detonation. That would be my guess too. But seems like it would be safer to do the former, though that would suggest additional programming logic, which is additional complexity, which then suggests that the simplest answer is the correct one . Engine management would have to be taking advantage of the extra octane though to get that power. The more powerful gas alone wouldn't do it. All things being equal/unchanged, you'll get the most power from the LOWEST octane rating your engine can utilize fully, as it will burn the quickest.Question is: Does the ECU baseline tune assume bad gas is being use and then scales up the parameters, or does it assume race fuel is used and scales back the parameters. My gut would be the later, except, instead of assuming race fuel, it assumes high quality normal pump gas, and scales back parameters if lower grade fuel is detected. But, like I stated, I really don't know, just surmising.
The extra power felt can be attributed to the increased energy content of the race fuel and is not necessarily due to engine management.
