Ngauge issue
LETHAL
LETHAL
From the D but in the NC
Asheville, NC
Kevin
2018 GT A10
mikes2017gt
San Antonio, TX
17 GT Prem M/T 3.55
Leave the trickle charger connected while flashing and you should be OK. If it does not work, you know you can eliminate the battery voltage as the problem.
LETHAL
LETHAL
Asheville, NC
Kevin
2018 GT A10
The voltage drop thing is no joke. It got to 50% last night and I tried it. ONCE... and it took it immediately back to 25%.
Why are these batts so low?
Draklia
Dry Land
2017 GT
Mine was about 1/3 dry when I bought the car so I topped it off with distilled water. Guessing batteries don’t last as long when they are low on water.
Nonsequitur
Taiwan
Mark
2018 Mustang GT PP1 Euro Spec - 2014 Focus ST with EFR7163
It's a good idea to have a charger on your battery when flashing a tune. I've seen once too many times where someone bricked his ECU because the battery died while flashing....
Zinc03svt
usa
stang
In high 90 degree heat about 125 in sitting traffic was as high as mine gets. In 60’s never much over 85-90. Weird...
LETHAL
LETHAL
Asheville, NC
Kevin
2018 GT A10
Yeah..so..
Battery was at 100% and left the charger on while I tried the down load process. Ngauge immediately again went to "BATT" warning and same deal as yesterday.
I put the JLT back on and started the car. Battery warning shut off. But as soon as you shut the car off the Nguage displays it again.
I think I have a cable issue or something is wrong with the Ngauge.
AZ18yote
Arizona
Bryan
With the battery at 100% and with the charger on it... you may be on to something no reason you should get a charge related failure in that scenario.
