New Michigan plate installed without a frame.....
Jerry Carguy
Michigan 48169
Jerry
2021 California Special Black exterior
Finally arrived.....had to use some trim as a surround. Oh, also note the exhaust tips... I wrapped them with fake CF vinyl and applied the same trim around the outside. The stock pipes looked unfinished being just a dull stainless cut off at an angle. Ford should have at least gave them a rolled treatment. JMHO.
Looks good, great choice of personalization statement!
If you're looking for a good plate cover with thin black framing, I have always used this type below for all my vehicles. They're also available at many auto parts stores and online.
https://www.etrailer.com/License-Plates-and-Frames/Cruiser/CR62051.html
Here's the images I snipped from their website to show that this type of cover does not interfere with the face of the plate, nor does the framing:
And as you see the cover itself is not bulky or "pronounced" like others. It's a very clean design and meets the allowable "plate covers" in most States. Some States won't allow plate covers if it blocks or interferes with any of the lettering on the plate facia.
Here's another trick too:
Before installing, on back side get the plate situated into the frame, then apply clear silicone around the outer edge where the edge of the plate meets the edge of the plastic. This will prevent moisture or water from getting in between the plate face and inside of the cover.
Strokerswild
Shallow and Pedantic
Southern MN
Things With Wheels
I run one of these on the rear, nice and clean:
Jerry Carguy
Michigan 48169
Jerry
And as you see the cover itself is not bully or "pronounced" like others. It's a very clean design and meets the allowable "plate covers" in most States. Some States won't allow plate covers if it blocks or interfere with any of the lettering on the okate facia.
Before installing, get plate situated into the frame, then on the back side solely clear silicone around the outer edge where the edge of the plate meets the edge of the plastic. This will prevent moisture or water from getting in between the lkate and inside of the cover.
Awesome solution, I like it better than what I was forced to do. Yes, Michigan is one of the states where you can't cover any part of the plate.
Thanks for the info😎
KingKona
Virginia
Shlomo
2019 GT
No frame is best frame.
Those vintage MI plates are beautiful.
Chef jpd
Brooklyn, NY
You might want to consider ceramic coating the plate for protection.
Did mine and they stay super clean.
1WILDHORSE
Michigan
Geers
2016 Ford F350, 2023 Mach 1
Nice work, what did you use as a trim for the exhaust?
