New Brakes, question.
ModernSVO
East Coast
2020 Mustang
I've don't brakes before, mostly single piston type or the f-150 2 pistions on one side.
How does one push the 4 pistons back in the unit at once. I'd assume doing one side with a "c" clamp would just push the other two out of their bores. What do you use. I'm sure there is a tool for this.
I just don't know what search words to use to get a list of what I need on a search engine or tool search.
Thanks.
robvas
MI
2011 GT
You might be able to just slide the new pads in. Otherwise just use a c clamp on the old brake pad to push each side in one at a time.
There are brake job vides on Youtube if you want to watch the whole thing before you do it.
Lbj
Washington court House OH
Larry
2019 mustang GT. A10 auto
I just did my breaks on my 2019 GT and I had to turn the pistons clock wises to get to go in they don't push in
Yorkshire_OH
Cleveland Ohio
James
2019 Mustang GT Premium
Whilst I've not done it on my Mustang, isn't it just the rears that need to be screwed back in?
JTM88
Tulsa, OK
Jason
'20 Mustang GT ESS G3/G4 PP1
SVO MkII
IL
2018 Ecoboost, 6sp, PP, 2017 GT Convertible
For the front, just use a wide blade screw driver and insert it between the old pad and the rotor and push the pad back, compressing the pistons back into the caliper. Then remove the old pads and slide in the new ones. I've done this trackside, takes 15-20 min (assuming the brakes are cool!).
