M3Convert
American Muscle Noob
- Apr 1, 2015
- New England
- Deep Impact Blue GT Premium
I "meant" to get a video...M3C,
You mentioned "a video to come". Do you have one to post?
Did your 13" Helmholtz tube cancel the full 1,000 rpm drone range? I've heard it only cancels about a 400 rpm range. UNfortunately, my drone is from 1400 to 1900 rpm (1750 peak), so I'd need a 37" Helm. res. tube. :eyebulge:
Any idea which ( inline resonators, x pipe, Helm. res tube) mod did the most to stop drone? Helm. I'm guessing.
If you look at the tube, it is stepped, so the volume inside increases, which will affect the sound (cf snare drum vs bass drum), effectively shortnening the tube...in my picture, it has gone from a "calculated" 36" tube, to an 18+" tube. The tube can also be doubled back if you go with a straight tube. The resonator tube can be tuned by sliding the pipe to different lengths on the Helmholtz pipe, like a trombone, to get the desired supression point. This means different diameter pipe can be used to achieve the same goal. Once you have the right supression, the tube is welded at that position, so you don't have to guess and commit. This will take a little shop time, but you will get a truly custom exhaust note!
What happens is the drone is suppressed to a much quieter level, similar to the background of an aftermarket exhaust, rather than totally eliminating it. The response is analog, not digital, so the supression builds and wanes gradually, so a range of drone is supressed, rather than just on/off at one frequency
