Need help buying wheels
BlueJay
Alabama
Jay
2020 Ford Mustang GT
Hey guys, i wanted to ask in the forums about some wheel question I have. Its my first time buying wheels and I dont wanna go thur the hassle of buying then returning and that whole long process.
I have a 2020 Mustang PP1 and I was looking at some ESR CS8s. ESR says this 19x9.5 +35 CLEARS MUSTANG PERF. PKG BREMBO/ STI.
They dont have those in stock, Ive seen some people runin the same wheel and have a 19x9.5 +22 offset with the bembos and still clear thats why im unsure, of what ESR is claiming.
If I got the ESR 19x10.5 +22 offset would they cover the brembos?
Also would a 10.5 in the front be outside the fender?
Thanks, Jay
LOL WUT
Illinois
19 GT
Thanks, Jay
10.5 +22 is going to have some decent poke outside the fender on both the front and rear.
ESR has some great looking wheels but unfortunately only a few of their wheel offsets are ideal and they come on the narrower offerings.
BlueJay
BlueJay
Alabama
Jay
Makes sensem
So basically a 9.5 +22 is prob gonna be the best option without having it poke out way to much. but im not sure if a 9.5 +22 would even cover brembos since people have run that size with no problem.
I want like hella flush fitment. So having the right offset and size is hard.
MAGS1
Somewhere in Middle America
Mark
2022 Mustang GT
Check out Apex EC-7 in 19x10 +40. Similar design to the ESR wheels you were looking at and with the proper offsets. They will clear the PP Brembos as well
Austin1992
Indiana
2019 GT PP1
Read the title and thought to myself “dam, wish I would’ve known all I had to do was ask and these guys would’ve helped buy my new set of wheels” lol
Skye
≈39N
"Skye" Mach1 N2144
^ This.
Factory Mach 1 front rim is a 10.5, +24; this results in a .5 inch / 13 mm poke.
A 9.5, +22, would be a .5 inch / 13 mm less, on each side of the rim.
19x10, +35, square, is a very common setup. You'd have a bit of additional grip from the wider rim/tire profile versus a 9.5. And you'd fill the wheel well a tick more than a 9.5. I see where these are currently out of stock in the maker you're looking into. Could be worth waiting for.
I'm using a 19x10, +35 setup from LMR, front and rear; these clear the brakes and suspension just fine. Simply remove the old rims and bolt the new ones on.
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Thanks, Jay
Hey Jay, this is Junior over at Need4speed I have a s550 mustang aswell. On my personal car I have have ALOT of different wheel and tires sizes. I have found that a 10 wide wheel with a +35 offset up front is perfect for these cars and clears the brembo brakes. For the rear a 11 wide wheel with a +50 offset is perfect also. With a 275 tire up front and a 305 tire for the rear. You won't have any issues with camber or alignment you can usually get a nice factory alignment with the wheel/tire specs.
