Need help - brake pedal losing pressure
GJarrett
Bradenton, FL
Gerald
2017 EcoBoost Premium
When I hold my brake pedal down with pressure (like at a red light) it will slowly and gradually move down to the floor. If I pump it quickly and hard I can hear air hissing during each pump. There is no brake fluid leakage anywhere. I am assuming there is some sort of air piston that transfers brake pedal pressure to the master cylinder (?). Can a bad master cylinder act this way?
Can someone enlighten me on what is happening, what the fix is, how easy to DIY, etc?
SHOdaddy68
Washington State
Daryl
2015 GT PP Premium w/Recaro
Sounds like a leak somewhere. A caliper, line or the booster. If you're not loosing any fluid and the reservoir level is good, my guess is something in the booster. Replacing a booster/master is not a fun or easy task. If you don't have the expertise to diagnose and fix it yourself, don't compromise your safety. Take it to a shop and have it checked out ASAP.
GJarrett
Bradenton, FL
Gerald
Yeah I'm not losing fluid... I'm a pretty competent DIY but not exprienced with boosters and cylinders, and too old to be in the mood to mess with a job like that, if that's what it is.
If it is a leaky booster will it keep gradually getting worse or can it decide to catastrophically completely fail instantly?
SHOdaddy68
Washington State
Daryl
It will probably continue to degrade. Don't know if it will or could completely fail but I would not take a chance with it.
Unas2k5
Detroit
Samer
2015 Mustang GT, 2021 Explorer ,2019 Impala
Brake booster definitely since there’s hissing
GJarrett
Bradenton, FL
Gerald
Thanks for the insight. I have a trusted local shop and will take it there to get confirmation and estimate.
