Need advice for brake pads and rotors.
MYSNAKE
2016 GT 350
Going to replace brake pads after 12k miles should I replace the rotors also?
Next Phase
NC
Mopar
I wouldn't for a street car, unless the rotors are significantly worn (per caliper measurements).
Ford will most likely recommend new rotors.
Eritas
2016 Mustang GT
It's highly unlikely you need to replace the rotors.
1 old racer
Fontana CA
Will
if you are concerned, take the rotors to a shop that will resurface them. I think I paid 10.00 a rotors the last time I had mine done.
MYSNAKE
MYSNAKE
2016 GT 350
Best I could do without taking the wheel off. Crazy schedule with school and the NASCAR weekend coming up.
ZX3ST
STL
2018 GT350, Kona Blue, J3116
Rotors look like they're in decent condition without any cracks. If they're within minimum thickness I'd keep using them for the ~$500 it'd cost to replace. If memory serves it's 34mm minimum thickness, but it should be engraved on the center section somewhere.
Austinj427
CO
2017 GT350
You're still 2-3mm to the sensor on those pads.
I would keep running the setup.
Also, the rotors look good. Just measure them like everyone else says. I doubt they are to minimum thickness.
MYSNAKE
MYSNAKE
2016 GT 350
Thanks to everyone, I'm 20 and still have a lot more to learn.
JAJ
Vancouver BC
2016 GT350 Track Pack
Those brake pads are fine for another 12,000 miles of street driving and the rotors look great. Just keep going and check in again later.
