Necessary Additions for Proper Alignment
BVLCK_S550
North Georgia
Mason
2019 Mustang GT PP1
So I’m about to pull the trigger on quite a few suspension parts for my 19 PP1:
  • Ford Performance Track Shocks & Struts
  • Eibach Sportline springs and sway bars
  • Maximum Motorsports camber plates
  • Steeda rear subframe alignment kit
  • Steeda billet rear shock mounts
I want to make sure I can get as close to an OEM alignment as possible. Is there any other parts I would need that aren’t listed above?
Thanks!
Vicr
Fortuna Foothills, AZ
Vic
2015 Mustang Ecoboost Premium
If you go with the Sportlines be aware that you be changing the geometry of the suspension which will need to be corrected. You will also need the Steeda Bump Steer kit which will be adjusted during your four wheel alignment. The only other thing I can add is with those springs you may not want to do the swaybars, it may be a waste of money. My Mustang handles like a slot car with my set up and I'm on OEM swaybars. See my sig for my upgrades.
BVLCK_S550
BVLCK_S550
North Georgia
Mason
2019 Mustang GT PP1
Okay I see what you’re saying!
Definitely will add the bump steer kit to the list. I’m on the fence between vertical links and toe links now. I know I could just go ahead and buy both but I’m already about to throw so much $$$ into this suspension setup. (at least I’m attempting to do all the installation myself) Are some adjustable toe links needed to get the rear alignment where it needs to be?
WD Pro
United Kingdom
Lime GT
As you have a PP1, aftermarket toe links are only adding ease of adjustability (no performance or alignment benefit) :like:
WD :like:
GrabberBargeCaptain
CA
I'd say skip the rear billet mounts, not needed.
GrayMater22
Sanford, FL
James
22 Mustang GT Premium
Thanks!
It’s good to see you are doing the irs alignment, but the #1 suspension upgrade to mine was the steeda irs brace, it really ties the chassis and unibody together, there is a lot of slop there and springs, shocks and struts do not correct that sloppy rear end.
BVLCK_S550
BVLCK_S550
North Georgia
Mason
2019 Mustang GT PP1
I should have mentioned before that I already have steeda irs braces and the 2 point k-member brace!
BVLCK_S550
BVLCK_S550
North Georgia
Mason
2019 Mustang GT PP1
Only reason I was considering it was because of the amount of drop from the sportline springs and the more aggressive shocks. I figured it’d be a necessary precaution. This car isn’t my daily driver but I tend to drive it hard whenever I do get it out!
