MY19 GT AUTO ISSUES
I am dili
Melbourne
My19 GT
Hi all. I have a my19 GT 10speed. Ever since I got it ive had transmission issues. Its been remapped twice and same thing . 5gear has a massive flat spot and after the transmission oil temp gets to half way, it gears down from 5 to 3rd with a thud. Anyone else have similar issues ?
Andy13186
I do remember hitting some lower RPM limiter in 5th on the stock tune...
Get tuned in other words
Andy13186
How about the hard gear downs? Will a tune solve that
I paddle shift, 95% of the time personally. But tunes are always worth it on every car ive had. Best value mod of all time imo.
gmupatriot
Northern VA
2018 Mustang GT (Orange Fury), 401A, A10, 3.55
My 2018 GT does exactly that. I have not taken it in yet to the dealer for a check-up.
Matco
Camarillo Ca
2019 F150 2018 Mustang GT 1996 Ford Bronco
mine did the same thing, it was 2 quarts low on transmission fluid from the factory or so my dealer says
BlackandBlue
Mustang
5th is a very harsh gear in my car also. I don’t have any downshift noise but 5th shifts hard in sport plus even at 25% throttle. I can manually shift the car and it seems normal. I figure it is something the car has learned from the way I drive.
I generally pull hard to the top of third let it shift into 4 and let out or part throttle.
I would see if I could replicate it with the paddle shifter to see if it is a software or hardware problem.
The low fluid levels have been found to be an issue in the early 2018 builds - have not heard of any 2019’s found with low fluid (yet).
The most common reported issue with the S550 10R80 has been bad valve bodies - which affects shifting function and performance of the transmission.
Here is the 10R80 Ford TSB/SSM thread I had started a while back. I’ve kept it up to date for docs pertaining ONLY to the S550 10R80.
https://www.mustang6g.com/forums/threads/2018-10r80-a10-most-recent-tsb’s-in-here.102918/
Lo Pony
W. VA.
Take me home
86 GT, red; 88 LX 5.0, black; 95 GT black; 99 Cobra with mods (still own); ā€˜16 GT, PP, manual, Ruby, drivetrain vibration!; Traded for ā€˜19 GT, A10, velocity blue, love it.
I have 10k miles and 4-5 shift is getting wonky. I’ll do a reset and see how it goes.
