pinero61
At least 70%.. lolSo I got to page 5 of this thread and I have come to the conclusion 99% of the ecoboost that blow up are from user error.
You can with a stock tune. If you're going to tune, particularly a turbo car, know what you're getting into. An extra 5 psi of boost is a significant increase in cylinder pressure and pre-ignition is more likely the higher the pressures.If you can't give your car 25% throttle in any gear, the engine design is faulty and unsuitable for purpose.
If you can't give your tuned car 25% throttle in any gear, the tune is faulty and unsuitable for purpose.You can with a stock tune. If you're going to tune, particularly a turbo car, know what you're getting into. An extra 5 psi of boost is a significant increase in cylinder pressure and pre-ignition is more likely the higher the pressures.
Agreed. I'd be wary of daily driving anything with over 20 lbs of boost (stock max level +/- 2 from there, if I recall)If you can't give your tuned car 25% throttle in any gear, the tune is faulty and unsuitable for purpose.
Yea, you are not freaking crazy. I'm crazy.... I still have mine!!!!! :eyebulge:And I have ppl tell me I'm crazy for trading last night
Glad you understand.gotcha so DI engines all come from the factory correct, only aftermarket tuning can create LSPI, and oil vapor/residue/composition has nothing to do with LSPI. Only incorrect tuning?
just making sure I clearly understand what you're saying.
$40k for a GT? Only if you get a premium and pay msrp. Mine was like $31K OTD from Koons ford in Baltimore. Optioned with TY, ato trans and black accentYea, you are not freaking crazy. I'm crazy.... I still have mine!!!!! :eyebulge:
Looking at the numbers... got mine for $33k... trade 25k.... new GT around 40k. If I blow my engine I can get fixed for what 7k (but then I'd more than likely want to trade it anyway and be out another 7k on the upgrade from 4 to 8cyl). Then again, I might just look for something else altogether...
I really wanted to keep this car for three years.
I contacted the dealer and will see if they will make me an offer I can't refuse. If not, I'll hang on to this one and hope it does not go boom.
I can say this is the first and last time I tune a car... not been a great experience.
Hi, what if I add CAI BOV and IC without aftermarket tune? Will LSPI happen? ThanksNo, what I'm referring to is what I said. Tuning most definitely affects the possibility of LSPI occurring; it is mainly due to improper ignition timing and fuel injection event timing. Improper ignition timing alone can send cylinder temperatures skyrocketing. LSPI can also be induced by excessive cylinder pressures, which is why a tune that increases boost above factory levels can result in LSPI.
And despite what you seem to think, DI engines are not diesels. They don't inject fuel all at once when the piston is at TDC; that would give the fuel exactly zero time to atomize within the combustion chamber.
Hydrodynamic lubrication provides an extremely strong film of oil to prevent the bearing journal from coming into contact with the bearing itself during operation. For example, only a few PSI of oil pressure is required to maintain bearing lubrication at idle.
The oil pump on the Ecoboost 2.3 is able to provide up to 60 PSI at only 2,000RPM. Therefore, even at 1150RPM, where is still more than sufficient oil pressure to maintain bearing lubrication, even under a load. It's not something to worry about.
Once again....Ford does extensive testing to ensure that your dreaded LSPI doesn't occur with the factory tune. It's MODIFIED vehicles that have the greatest threat of LSPI. My 2.7 Ecoboost will pull hills in 6th gear at 1100RPM without an issue, and that's on 87 octane. Do I panic and manually downshift it to 5th?? Of course not, because the factory tune is designed to allow the engine to operate safely under all conditions that may be encountered.
Of course you would like that, because you don't like to be called out for being wrong. Unfortunately, spreading nonsense and misinformation is not helpful to anyone, so I will continue to post the facts to clear things up for you.
None of those things will directly impact whether or not LSPI will happen. A good tune can help keep you out of the danger zone in an auto thoughHi, what if I add CAI BOV and IC without aftermarket tune? Will LSPI happen? Thanks
You mean a good tune will make it safer than stock tune?None of those things will directly impact whether or not LSPI will happen. A good tune can help keep you out of the danger zone in an auto though
CAI should have no effect on LSPI, as these engines use speed density and not Mass Air Flow.Hi, what if I add CAI BOV and IC without aftermarket tune? Will LSPI happen? Thanks
Lol a gt350 though? That's quite a jump in a year's time. I guess he'll be able to get a used one for around $50-60K by then
Thanks for reply. I was scared by these engine failures. Maybe I should keep the stock tune.CAI should have no effect on LSPI, as these engines use speed density and not Mass Air Flow.
A larger intercooler is beneficial, because it will improve the cooling of the air charge entering the cylinders.
A BOV is pointless, keep the factory bypass system.
That's never a bad idea.Thanks for reply. I was scared by these engine failures. Maybe I should keep the stock tune.
