My s550 shuts off for no reason
Gray5.0
2015 mustang gt
Hey guys..
so I have a manual 2015 premium GT, a while back when the RPM is higher than 4500 and I press down the clutch and come to complete stop or I want to make a U-turn the car shut off and dies!! This issue often happens and I can’t figure out why,
Other than that the car runs perfectly.
I changed the throttle body and checked for vacum leaks and everything is perfect
The car is FBO beast
lacanteen
Louisiana: Cajun Country
George
Does it do this with a full tank of gas? I'm thinking fuel pump. Just a guess.
Gray5.0
Gray5.0
2015 mustang gt
It doesn’t matter whether the tank is full or empty, it still shuts down.
and I checked the fuel pump, it works fine
This problem will drive me crazy lol
Danmg202
Oregon
2018 mustang gt- 401a - PP1
Had a similar issue on my 15 dealer blamed the air filter being damp(a new one did nothing
) , I put in a new maf sensor myself and it went from happening weekly to once in 2 months. Never fully got to the bottom of it before trading for an 18.
Gray5.0
Gray5.0
2015 mustang gt
i cleaned the maf sensor and did nothing!
is it possible that the catch can can be the problem??
Leroy
Southern California
2008 Shelby GT 2008 GT-500
You might have a sticking vapor management valve. It can pull vapor from the fuel tank while slowing and then not seal off causing a long decel stall. Disconnect and plug the vacuum hose leading to it to see if the issue goes away.
Good luck...
Ted
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
Puddintane
'17 S550
No codes? BAttery good? Secured nice and tight? No corrosion on the terminals?
kent0464
Virginia
Kent
1983 Ford Ranger, 1986 SVO Mustang, 2017 Mustang GT PP, 2017 F150 3.5 Eco
Hey guys..
My 17 GT PP MT82 did this a couple times, ended up being that I didn’t apply the clutch fast enough when coming to a stop.....no jerking or anything just shut off. Hasn’t happened since.
