Mt82 upgrades clutch recommend
Justgonna send it
NC
Ty
2019 GT 6spd ess G3 kit 120mm pulley , wendgerd tune & 2020 hpp eco
So my 2019 stang is In the shop getting forks replaced. Thing about upgrading the clutch to eliminate lockout and cause I’m sure a Barton shifter will definitely Void the warranty.
debating between
ram clutch vs mcleod rst Dose any one hear have any experience with either brand.
Mustang gt 2016
Oman
Alex
Mustang gt manual 2016
I have an rst clutch installed and you need more time to get used to it . It has a different bitting point feel and noisy lil bit specially with low rpm. All the noises are normal nothing to worry about and sometimes it cause hard shifting or going to first. This is my experience and i think it differs from one and another since its a clutch.
HoustonGT
Danville, CA
2020 GT PP2
I chose the RXT due to having a whipple. I also added a Barton hybrid attached to the transmission. Same as the RST, learning curve starting off in 1st. Still in breakin period, getting some "chatter" but people say it should clear up with more miles. Def more noise than stock, but the shifter being mounted to the Trans is part of it. So far, I like the combo...
Mustang gt 2016
Oman
Alex
You will get used to it soon or later. It took me 400 miles to get used to the feel of the clutch and when to shift. When i drive someone else’s stock mustang their clutch feels smooth regardless of being heavy or light. Also my mechanic told me to press the pedal at least 3-5 times from time to time when the car is on and in neutral position. This is the case with my RST. I dont know if RXT requires same procedure.
HoustonGT
Danville, CA
2020 GT PP2
I added a barton hybrid shifter at the same time. Brand new learning curve, with the springs the barton is much stiffer than the stock shifter. The springs will probably loosen up with time. Mounted to the trans so that adds to the different feel from the stock setup.
Mustang gt 2016
Oman
Alex
How much does it cost to have a barton shifter with installation ? I might consider an upgrade in the near future.
Temovic55
Saudia Arabia
GT500 2014, ROUSH II 2018
I did the Mcloed RST with SS lines and changed the pilot bearing ( high load ) aligned with the MGW X -SPEC shifter for better performance abilities.
Bought the RXT and yet still thinking to sell it as I was going 1000+ then I decided to keep it civil to 730ish
Popo5ohh
Northeast pa
16 gt
Might want to look into the exedy. I have that in my procharged 16 gt. No issues no chatter.great pedal feel.
MyStang
Michigan
2015 GT
Agreed,
Exedy ET05SRFD 2011-17 Mustang 5.0L Organic 23 Teeth 8 Bolt Twin Disc Clutch,
paired with MGW. Very happy no chatter, great peddle feel.
