MT82 1-2 shift
Nighthawk
St. Louis
18 GT
Hey all, bought a 19 GT about 2 months ago. Had a 14 GT MT82 in the past.
I am having a hell of a time on the 1-2 shift. Never had an issue in my 14.
RST clutch, Billet Flywheel, Braided line, MGW race spec shifter. It’s as if when I try to shift semi quick to quick I get locked out like I did in my 14GT on the 2-3 shift before I replaced the clutch. My next step will be to adjust the shift gates on the shifter.
Also, I have noticed that in city driving when I go into 2nd, 3rd and 4th that when it goes into gear it kinda tickles the shifter until it’s fully in gear. Then today it went away for a bit and fell into gear smoothly.
Anyone have any advise on this?
paulm1
Northeast PA
pau
2021 GT mustang
well the big stuff is done, maybe the shifter needs adjustment. I might try a stainless clutch line and switch the fluid over to BG synchroshift from op mustang.
Nighthawk
St. Louis
18 GT
Yeah, I will be swapping fluids soon to see if that helps
Zrussian13
Phoenix
I second adjusting the shifter. I used to get locked out on the 2-3 and once on the 1-2. After putting an aftermarket clutch in, it never happened again.
MrBD1348
Chicago, IL.
'22 GT MT-82
100% shifter adjustment. Didn’t realize how big of a difference it made on my Barton until I just went back and re-adjusted it. No more 2nd lock out and all the shifts are like butter with a new clutch
MD18EcoStang
MD
2018 Mustang Ecoboost
What's involved in a shifter adjustment?
MrBD1348
Chicago, IL.
'22 GT MT-82
For the Barton there’s a bracket on top of the cartridge that slides. Loosen it and try to engage all the gears easily with the car off. Then you tighten it back up. I had to drive after adjustment to be sure since the feel changed under load.
MrBD1348
Chicago, IL.
'22 GT MT-82
This is a video I showed someone of the Barton. Not sure about MGW
Deleted member 69311
Guest
How do you adjust a stock shifter? I’m curious if this is causing my shifting issues.
MrBD1348
Chicago, IL.
'22 GT MT-82
You don’t. Change it out. Seriously it’s probably one of my favorite changes I’ve made to the car
Zrussian13
Phoenix
Stock shifter isn't adjustable but if your on a stock clutch and having lockout issues an aftermarket clutch alone should change that. Guys who have done the shifter only can chime in whether a shifter alone would do tne same but I'm not sure. I'm running an lpxhd and stock shifter and have no lockout issues since install.
MD18EcoStang
MD
Hmm, I have a Steeda shifter and don't recall such an adjustment. 🤷‍♂️
