2018/19 MT82 owners - see TSB’s regarding busted 1-2 & 3-4 shift forks
Bane022
New York
Anthony
None
Secondly, this is the first car I have ever purchased by myself (also my first manual - had to drive it 2 hours home. If only this experience was recorded I probably would of went viral on YouTube). Should I print these TSB's and bring them with me when I get in contact with someone at a service center?
GT 550
Australia
Black GT MT S550
The TSB # should be sufficient, it never hurts to make sure they know what they should be looking at as some service places aren't as thorough as they should be. All the same don't worry if they can't quote them straight up as there's a lot of TSBs out there. Oh and as of now you're also having issues with gears 3 and 4, yes?
Bane022
New York
Anthony
None
I have only had issues with the transmission not wanting to shift into second. The shifter pops out of gear as if you’re throwing a ball at a wall and it bounces back.
GT 550
Australia
Black GT MT S550
No no, you *do have an issue (hint) for the purpose of getting current and potential future issues addressed in one go.
Bane022
New York
Anthony
None
Ohhhhhh yes that is what I meant. While I’m at it I’ll see if they’ll cover a TREMEC swap
mustang5o
Middle America
2023 Oxford White Mach 1 Handling Pack
Wouldn't that be nice. Maybe if they had switched to Tremec only for all Mustangs but as long as the MT82 is around we'll have to deal with it's shortcomings. I'm hoping to see a swap kit put out by Ford though. I had talked to Calimer about upgrading my MT82 or swapping to a Tremec and I Was told with Magneride and rev match it's a no go. We had a bad phone connection so I might follow up with an email to see if I can get more information. Otherwise that might push me to look at the Mach 1.
boB
boB
2019 GT PP1
Rev-match relies on an internal magnet and a sensor bolted to the xmsn. It would be difficult to add those to the Tremec.
mustang5o
Middle America
Except that Mach 1 will have Tremec with rev matching so I'm wondering if there will be a Tremec available with that feature to swap in. Actually I don't care about rev match as I can heel and toe on track but they also mentioned it not working with Magneride. Need to look into that more though.
boB
boB
2019 GT PP1
The shift mechanism is not that different between Tremec and MT-82 so I suspect it is easy enough for the factory to modify the xmsn for the sensor. Don't know what effect Magneride has on it, it's getting difficult to modify our cars!
Elp_jc
None
What does MagneRide have to do with the tranny??? Just curious.
Regarding the TSBs, the first and third are for 2018 vehicles. The second lists 'some 2018-2019', with no VIN range... BUT the date of that TSB was August 30, 2018. So that tells me vehicles built after that date should not be affected. Mine was built almost a year later (Aug 09, 2019), so not worried about that at all.
mustang5o
Middle America
I sent them an email to try and get a better explanation.
I suppose I could try a Barton or MGW along with the Steeda Spring I haven't installed yet. Plus a new clutch line and clutch eventually. Mach 1 sounds like a better idea more and more :).
mustang5o
Middle America
So Magneride also monitors gear selection and speed among other things of course to determine shock settings. The current MT82 with magneride cars has a sensor for that.
mpeychev
Phoenix, Arizona
Martin Peychev
I just recently lost 2nd gear, and 1st gear is definitely about to go, car is at about 33,000 miles. I'm taking my car into the dealership this Tuesday, guessing it's the forks, but who knows.
For anyone that has taken their car in. Did the new shift forks eliminate any lock out issues? Did they replace the forks that were broken, or replaced them all for preventative measures?
2018-2019 S550's w/ MT82:
REVISED TSB's as of January 5, 2023 for the MT82 1/2 Shift Forks (22-2373) and the 3/4 Shift Forks (22/2372); see attached pdfs
