Motorcraft oil filter versus ?
gtlaw
JcRoush hater
pittsburgh
a car
Notice there isn't any comparison to purolator I wonder of they are the oem of the motorcraft filter?
tsunami
Minnesota
2015 Premium EcoBoost Convertible
Is there much internal difference between the 820S and the 910S (EcoBoost Filter)?
gtlaw
JcRoush hater
pittsburgh
a car
I was also surprised my oem filter was quite different than the motorcraft fl-500-s
Mountain376
SE Michigan
'17 Camaro SS 1LE, '16 Camaro SS, '12 Mustang GT
I've cut open my fair share of oil filters. I'm not sure about "to-date", but at least what I cut open in the past and have also seen other post about, many of the Purolator and Motorcraft oil filters look damn near identical.
I try to stick to the Motorcraft, Purolator PUREone and WIX oil filters. Mobil 1 is nice, but the price is more than the preceding I mentioned and doesn't seem any better. I'd like to try the Purolator synthetic, but there isn't a version yet for the Mustang.
m6pwr
San Diego, CA
Richard
2015 Mustang GT Performance Pkg,Recaros
Here's a short video on how to compare apples to apples (filtration efficiency) with oil filters. [ame]
The consensus on the Ford forums is that Purolator make the Motorcraft oil filters. I've found it very hard to discover the specific numbers on the MC filters. I think most all the higher end filters (e.g. Purolator, Fram, Bosch, Wix, etc.) are rated around 94-98% efficiency at 20 microns (the smallest particle the filter will catch). And all these filters use synthetic filter media (e.g. "micro glass") rather than the less efficient cellulose. The Ford racing filter is rated 98% efficient at 25 microns (according to American Muscle - Ford Racing Tech Line didn't have a clue). I think it has slightly greater porosity to flow more oil (maybe a thicker oil, too), keep the oil pressure up and lots of oil pumping through the oil cooler. The slightly larger particle it will let through (25 microns) is almost irrelevant for all practical purposes. 5 microns is the size of a white blood cell. Anything smaller than 40 microns is invisible to the naked eye. So we're talking about how many angels can dance on the head of a pin when you compare the efficiency of many of these filters. If you don't track your Mustang regularly, or if you haven't significantly modded the motor, the stock MC should be more than adequate (that is also the opinion of American Muscle).
PS: The ISO test procedure to rate oil filters includes a test to determine how much stuff the filter will catch before it starts to clog up. This rating is expressed in milligrams I think. It would be a good metric to know in comparing filters but I've never seen it revealed anywhere. The total size of the media or the number of pleats may have something to do with that, but i'm just guessing.
I believe Ford has done its homework and the MC filters will work just fine at the specified drain intervals.
GT Pony
Pacific NW
What is the specified Motorcraft filter for the 5.0L Coyote? Is it the FL820S or the FL500S ... or can either one work?
GoBlues38
St. Louis, MO
Scott
2015 Mustang GT, Premium, 3.55, 20" Foundry, 6 Spd
meh. all marketting fodder.
I am 43 years old, and never have a witnessed or known someone who had an oil filter fail.
Buy a quality name brand filter and forget.
gtlaw
JcRoush hater
pittsburgh
a car
With how cheap the motorcraft is I can't see a reason not to use them
dgc333
MA
15 Mustang Ecoboost Premium
I had a Wix filter fail once. The crimp that holds the can to the base plate wasn't done properly and oil came pissing out as soon as I started the engine.
dgc333
MA
The FL820S has a metric thread and the FL910S has an English thread so they can not interchange. The FL500S has a lower bypass pressure than the FL820S.
I have a lot of Chrysler products over the past 35 years that called for the FL910S spec filter, I always used the FL400S spec filter which is longer and when there was lots of room I would use the FL1 spec filter. These all have the same 3/4-16 thread, gasket diameter and bypass pressure.
With the first oil change on my Ecoboost on went a FL400S filter. The design of the filter adapter on the block won't allow a larger diameter filter. This filter allows a full 6 qts of oil instead of 5.7.
dgc333
MA
Motorcraft is the aftermarket business unit of Ford. They make their own deals with suppliers meaning what they sell is not necessarily the same as what is used at the factory.
