Motorcraft 5W20 Synthetic Blend Motor Oil Wear Protection results!
1380KPOI
Orange County, CA
Poi Boy
2017 GT Premium
Last week I sent in an unopened quart of Motorcraft 5W20 Synthetic Blend oil to 540 RAT to see how well this oil performed in wear protection. I cannot believe how LOW this oil scored in terms of PSI. "Friction Fightimg Formula" my a$$! It looks like I will be moving over to Quaker State Ultimate Durability
#147. 5W20 Motorcraft, Friction Fighting Formula, API SN, synthetic blend = 72,144 psi
. The Wear Protection reference categories are:
. • Over 105,000 psi = INCREDIBLE wear protection
. • 90,000 to 105,000 psi = OUTSTANDING wear protection
. • 75,000 to 90,000 psi = GOOD wear protection
. • 60,000 to 75,000 psi = MODEST wear protection
. • Below 60,000 psi = UNDESIRABLE wear protection
The HIGHER the psi value, the BETTER the Wear Protection
millhouse
Simpsonville SC
2016 Ruby Red GT PP
You need to take his ratings with a grain of salt. If you found out the difference between modest wear protection and incredible wear protection meant the difference between your engine lasting 500k miles and 515k miles...would you still spend the money on the incredible wear oils? He makes some inferences in his testing results do not mean your engine will last longer with one oil over the other...as his tests do not replicate the wear in an internal combustion engine.
There are some very polarizing reads out there on the subject.
WildHorse
N/A or GO HOME
Home World: CLASSIFIED
'17 S550
TomcatDriver
Mojave Desert
2017 GT350 Magnetic w/black stripes
It is synthetic blend, and I would expect it to be outperformed by most full synthetics.
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
Full synthetic will last longer, but even a good quality non synthetic will do just as well as long as it's drained before the viscosity breaks down. If you were to insist on changing your oil every 3K miles you may as well use standard high quality dino oil.
wildcatgoal
@sirboom_photography
TBD
Most don't track/drag race the car yet change every 5K. Motorcraft is more than enough for that. I mean crap I put Walmart's SuperTech synthetic in my Silverado and did an oil analysis at 7,500 (10K changes according to computer) and they said it was probably good to 15K.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
The ranking has some relevance, but the real good info is looking at the wear protection at standard (230 F) and elevated (275 F) temperatures and seeing the difference. THAT is worth something for anyone that pushes their car hard (track).
millhouse
Simpsonville SC
2016 Ruby Red GT PP
It’s only worth something if you know its effect on your engine. The added wear protection may be great if you are using a flat tappet camshaft, but may not make a hill of beans worth of difference on any other engine. The data isn’t bad per say, you just have to judge the relevance on how it relates to your engine for yourself.
F1scamp
Upstate Ny
16 Mustang GT
The higher the protection the better when you are pushing the limits...8k rpm, double the hp rating of factory, etc. I just bought the quaker state, already had one coyote fail for inadequate oiling...
millhouse
Simpsonville SC
2016 Ruby Red GT PP
F1scamp
Upstate Ny
16 Mustang GT
From '13 before he put how he did the tests or his credentials on his blog. Quite a few engine builders and high end gear heads I know reference his blog and heed his advice. In the end, you have to go with what you are comfortable with.
jasonstang
Omaha, NE
2017 GB GT/CS 6MT
Engine design is more important than engine oil. LS engines will have lifter issues regardless what oil you use.
mustang1
Dallas, TX
2016 Mustang GT
gt350 has a higher flow oil pump than the gt so I agree with engine design over oil. You can run the GT at 8k , high heat, or double the power but its out of scope. Probably like wanting the MT82 to handle 500 lb ft and power shifting.
jasonstang
Omaha, NE
2017 GB GT/CS 6MT
I thought the GT350 has the same oil pump gear so how can it have higher flow?
Coyote Red
Port Lavaca,Tx.
Alan
2016 5.0 Coyote Red
The Ford Racing oil filter has a higher rate as well as a better "bypass feature".
