Modifying As-Built Data Guide
Jww92201
Palm Springs
Mustang
Boggus
Cypress
16 Mustang GT PP
Anyone in the Houston area doing this? Would love to have a couple of things changed.
law242
Arizona
2015 Mustang Ecoboost Premium
Please let me know if I am doing something wrong... have a 2015 mft and I tried changing the opening screen to the cobra and the cobra r logos and both show they loaded, and both make the sync run its update but neither work. Is there something I am leaving off other than changing that one portion of the code?
jstump2490
Ohio
2015 Mustang GT Premium
I don't think the 2015 has this ability. The GT350 came out when Sync3 was introduced and only Sync3 has the Cobra wallpapers I believe.
Mtipton
Vancouver
You can only do this on sync 3.
Mustang_GT
Martha Lake
Kevin
2016 Mustang GT PP - Triple Black
Splash Screen.
The 2015 MFT uses a different splash screen, so even though you can select it in FORScan, only the stock one will play I believe. I have a 2015 coming in soon so I will take a peek. I see in the 2015 files they are a mov file. On the SYNC 3 system I only see disk image files. Another challenge! :crazy:
pardoneo
Spain
Ex-'16 Mustang EcoBaby // Current '16 GT Convertible
pardoneo
Spain
zackmd1
Zack
Drive Modes enabled on a 2015 V6!!
AB values likely only work for a 2015 V6 or EB but just search the data lines posted for the correct vehicle trim (EB,GT) and year for compatible AB data.
IPC
720-06-01: 6C7F - 8000 - 18B1
ABS
760-02-02: 0200 - 117E
Credit goes to [MENTION=29038]mustangmike86[/MENTION] for initial discovery and activation on his 2016 GT. His thread: http://www.mustang6g.com/forums/showthread.php?p=1742359#post1742359
Note: Requires an MFT or Sync 3 swap to get the 4th toggle on the radio bezel.
Spart
Midwest
17 GT350
IPC
ABS
NICE :cheers:
zackmd1
Zack
Can confirm that the above code DOES change throttle response and transmission behavior (auto)! So it looks like I have fully functional drive modes on my vehicle.
Spart
Midwest
17 GT350
I'm mostly shocked that it's working on a V6, since there is no factory premium model.
zackmd1
Zack
I was surprised as well! Was not expecting any amount of AB data to work for that exact reason. This V6 never came from the factory with drive modes. Best I can figure, the drive modes are controlled by the ABS module alone. The ABS module augments the throttle inputs and shift points so the PCM has no bearing on the mode behavior. That would make sense as the V6 most likely has the same ABS module and transmission as the EB.
Spart
Midwest
17 GT350
That makes good sense.
