Modifying As-Built Data Guide
Dary
IN & KW
2015 Mustang Premium GT
Seems like NightmareMoon is right as far as it is a 15 or 16 GT. Trans Oil Temp is stuck at 15° Celsius - and right now even outside temperature is 30° (86 F).
So maybe this is a 2017 feature?
My 15' has it and it changes as I drive. I believe this feature (or sensor) is not available on manual trans.
fionic
spaghettios and cheerios
IL
15 GT PP
so these are confirmed working for automatic 15+ ?
0720-06-01 xxxx 0xxx xxxx No axle or trans oil in ipc
0720-06-01 xxxx 1xxx xxxx Axle oil temp in ipc (auto only)
0720-06-01 xxxx 8xxx xxxx trans oil temp in ipc (auto only)
0720-06-01 xxxx 9xxx xxxx both axle and trans oil in ipc (auto only)
also, the double honk disable has already proved itself great by day 1.
gt_stang
S550.GURU
Switzerland
s550.guru
Lars
2016 GT Premium
btw. Lock/unlock feedback silencer (no lights) works on my 16GT. Something for your special purpose, fionic? ;)
fionic
IL
15 GT PP
where did you see that modification? I would love that, yes. No special purpose, just don't like bringing attention to myself.
although... I do like confirming my doors are locked by looking at the lights.
talking about 726-56-01 and 726-58-01?
I think mattlqx in the GT350 thread added Axle Oil Display with 7F6D 1664 9E32. My OBDLink MX has not arrived yet so I have not tried it.
Engine oil TEMP!!!
Did I miss a post where someone found how to activate that?? Or is that display from a GT350?
fionic
IL
15 GT PP
Engine oil TEMP!!!
I missed that too... It would be great to have real numbers as opposed to 'low/normal/(high? never got this hot)'
judging by the magnetic suspension on the display, it's from GT350. need to find this one.
Two other questions:
1) It's been said if in the future there is an engine swap, that the VIN is in some of the modules and in order to have a successful swap, either the donor car has to supply the entire harnesses and modules or the IDS system would be needed to modify the receiver modules to match the donor VIN - Fact or Myth? Can the VIN # be changed using the As Built programming?
2) Is there a way to reactivate or "refresh" Sirius using a Dealer code after it expired? I downloaded the refresh app from Sirius that Dealers use to turn it back on for cars on their lots, but don't know the original Dealer code to do a refresh. Haha... Prob not, but just figured since you're all having fun, I was wondering if this was also in the As Built Data too.
fionic
IL
15 GT PP
1) It's been said if in the future there is an engine swap, that the VIN is in some of the modules and in order to have a successful swap, either the donor car has to supply the entire harnesses and modules or the IDS system would be needed to modify the receiver modules to match the donor - Fact or Myth? Can the VIN # be changed using the As Built programming?
1. well, it's in the bcm, though I'm not sure forscan will be able to write them. here(thanks dan)
726-09-01 VIN #: (first 5 characters in ASCII converted to Hex)
726-09-02 VIN #: (character 6 of VIN in ASCII converted to Hex)
726-10-01 VIN #: (characters 7-11 in ASCII converted to Hex)
726-10-02 VIN #: (character 12 in ASCII converted to Hex)
726-11-01 VIN #: (last 5 characters in ASCII converted to Hex)
confirmed this on my mustang.
2. I would think definitely not. you need to connect to their satellites, so you probably need to have a valid 'account' with them.
dotJake
Queen Creek, AZ
www.sdyoung.com
Jake
2017 White Platinum GT Premium
Possibly the case. My '17 is an auto and displays trans temp.
There we go, thanks. Was Trans Oil Temp Gauge enabled by default?
I know this was for Dary but in '17 yes by default.
gt_stang
S550.GURU
Switzerland
s550.guru
Lars
2016 GT Premium
Yes, -56-01 for key 1, but a little different from the f150 guys. I think it was
0000.0000.01 enabled
0000.0100.01 disabled
-58-01 for the piezo sound generator (I think it's that chirping sound) doesn't work for us as we don't have it AFAIK.
papinist
The Italian Pony
Tuscany, Italy
Stefano
Mustang EcoBoost MT Race Red EURO - NO MORE
Are you talking about the honk confirmation when locking\unlocking? The one I'm looking for to enable in EU spec?? :D
