MGW with Steeda trans mount insert
whatsup62
Jupiter
Like the title says. Just purchased the MGW shifter. I have the Steeda trans mount rubber insert already. Should I leave it in or remove? Anyone running both?
gsxr1300
MA
Jason
2023 Mach 1 2015 Mustang GT PP (Sold)
I have both installed, just didn't take it out.
zuki_dan
North Carolina
15 Mustang GT Premium M6 TY
I had one but when I installed the MGW I removed it. The reason I installed it was to quit missing the 2-3 shift. With the MGW I had no reason to keep it. I would also get a low rpm low speed vibration in the floor pan after I installed the bushing. It did take care of about 80% of the sloppiness in the stock shifter though.
evo8904
I'm a member???
Tampa
Luther
2017 Ram 4x4
I have both, it is amazing!
whatsup62
whatsup62
Jupiter
Thanks for the replys. I was thinking more along how NVH would possibly increase with the direct mounted shifter. I agree the bushing made a world of difference on the stock shifter.
Banjo
Jacksonville, FL
Bill
2015 Ecoboost PP manual
You can always drill a ~1" hole in the big flat part on the bottom of the bushing to alleviate the NVH issues. I drilled mine before I installed it so I don't know what it would have felt like originally but I don't feel like it added any harshness to the car.
CrazedAntelope
San Jose, CA
Chad
Ecoboost Premium PP
Isn't the MGW a transmission mounted shifter only? Meaning the MGW shifter is not connected to the body at all?
The Steeda trans mount insert is designed to reduce movement of the entire transmission so that the stock body-mounted shifter will perform better.
Although I have not tested this, I suspect the Steeda bushing will only increase NVH, and will not actually help with shifts when paired with a transmission mounted shifter.
whatsup62
whatsup62
Jupiter
My thoughts exactly, why I posed the question in the first place. The bushing is easy to remove so i will leave it in for now.
TwinReverb
OKC
Alan
2016 Mustang GT PP
I had the trans mount installed and it did increase noise in the car. I had it on for maybe 2 months and on Thursday I drilled a 7/8 hole in the flat part and it did away with the majority of the noise and maybe a little vibration. The part itself didn't add too much vibration to begin with IMO.
The part itself added such a benefit to the stock shifter I didn't want to get rid of it. I am installing an MGW in a month.
