LG23
Writing this quick review of the Steeda transmission bushing because I wish I had read something like this before purchasing.
Many people seem to have issues shifting into 2nd or 3rd and don't like how notchy the shifting is. Personally, I have not had any misshifts and dont think mine was very notchy to begin with. I bought the part thinking it will just make it even more solid.
Install was pretty straightforward and easy. I drilled a 3/4-1 inch hole into the center of the bushing to remove some NVH. The bushing can be a huge pain to push into the holes. It is a very very tight fit. Sucks to do under jack stands.
I drove around for a few days and noticed there was slight improvement in trans feeling more solid, there was definitely a little bit less slop. There was also definitely a bit more transmission noise, a slight overall humming and some other noises at low rpms etc. The very slight improvement was not enough to justify the slight vibration and tranny noise I was getting so I removed the bushing, it was annoying to hear the slight grinding and humming noise- clutch sounds seemed louder as well.. I removed it and just drove the car now without it and the cabin is much quieter/no vibration and the shifter barely has more slop. If I ever actually get concerned about it I'll probably just get the MGW shifter and be done with it.
Overall, this part IMO is only worth it if you feel you are missing shifts very often or that your shifter is extremely notchy. I didn't have any issues missing shifts without the bushing and I purchased thinking it would make it a bit more solid but it definitely came with annoying NVH even after I drilled the hole. It does its job but for me the small difference really did not justify the noises it caused during daily driving. :shrug:
