MBRP CATBACK CRACKING MUFFLERS
CwmGT
GA
Cooper
2016 mustang gt PP
Good afternoon. My name is cooper and I'm very new to the forum. Just some back ground on the car. I have a 2016 mustang gt pp. Stainless works cat delete long tubes, and a mbrp catback that came with the car. One muffler weld completely cracked so the muffler is basically hanging by hangar. The other I can see is starting to crack. My question is should I just get new mufflers welded on or replace the whole catback? If welding new mufflers is an option, looking for suggestions for moderately loud deep mufflers. Thanks in advanc .
I Bleed Ford Blue
North East OHIO
Go to american muscle and they have sound clips for most of the mufflers/cat backs they sell. But be warned, long tubes and cat deletes will ratchet up the decibel level more than what you hear in the sound clips.
hemistar1
Hampton, VA
Tim
2019 Mustang GT PP2, 2017 F-150
All depends on budget and sound. On my 15 I had 3 inch flowmasters and a summit racing universal xpipe and then I saved some loot and got a Corsa axle back.
The flows were cheap and loud all the time. The Corsas were expensive and loud when I got on it but little or no drone for daily driving.
Recently I got a 19 GT and added Borla cat back ..couldn’t be happier.
CJ pony parts has tons of videos and sound clips and if you need used ones the for sale section here is a great place to start.
CwmGT
GA
Cooper
2016 mustang gt PP
I guess my question would be to just weld in new mufflers or go for the whole cat back
vanquishvzla
Jacksonville - FL
2015 Mustang GT 50th anniversary
it is normal... i have the same MBRP catback (came with the car when i bought it) and both welding between the pipe and the muffler is broken... i just had mine redone by a local shop and no problem... you decide.... $50 with local shop or +$600 with new catback
Andy13186
Yea I would get a muffler shop to fix the welds then spraypaint them with high temp paint, unless you just want a new system. If you live in a corrosive environment you may want to spraypaint the welds with high temp paint before installing so they dont rust.
AZboost18
AZ
Edgar
2018 mustang
Yeah go to a muffler shop who can repair this or if you have the cash order a new muffler.
illtal
those sound like aluminized steel. they don't last long, I'd either weld something in cheap until you know what you want or another failure occurs then get what you want,
Where are you in GA? I live in middle GA.
Edit:
I see you're in Savannah, I have an exhaust I'll be able to sell you for cheap after I install my new exhaust. are you interested in something loud?
