Max rwhp on Gasoline factory fuel system
Discussion in 'Forced Induction - 5.0L V8 Engine' started by SJ-KY, Mar 16, 2020.
  1. SJ-KY
    SJ-KY Well-Known Member
    First Name:
    Stephen
    Vehicle(s):
    Gt 350
    Dec 11, 2018
    Forest Hills KY
    46
    All,
    Looking to to go the Procharger route with only a boost a pump on my 19 a10 Gt... I’ve seen where some have made 680-700rwhp on 93 but just curious how much further the fuel system could be pushed on let’s say an adequate race fuel that’s not oxygenated like c16 or something along those lines? Any good info would be much appreciated..
    Thanks
    Stephen Jessie
  2. moffetts
    moffetts Well-Known Member
    Vehicle(s):
    Black Whippled 2015 GT PP
    Nov 30, 2015
    San Mateo CA
    821
    239
    0   0   0
    It’s not a good idea to “push it” much beyond that.
  3. OP
    SJ-KY
    First Name:
    Stephen
    Vehicle(s):
    Gt 350
    Dec 11, 2018
    Forest Hills KY
    46
    Why is that? Because of injector duty cycle is maxed out on gasoline or fuel pump runs out of steam even with the boost a pump?
  4. Avispa
    Avispa Well-Known Member
    First Name:
    Richard
    Vehicle(s):
    2016 Mustang GT/CS convertible
    Dec 5, 2019
    Oldsmar, FL
    297
    172
    0   0   0
    You can calculate what you might need both for injector size and pump capacity. For safety, use .550 lb fuel/HP/hour. Use .8 (80%) for a safe maximum duty cycle on the injectors. Use 90% FPDC for safety on the pump. Gasoline is about 5.9 pounds per gallon. 700 RWHP is 385 lbs/hour (119 gallons, 464 liters) fuel. You'd need 60# injectors and 515 l/hr pump at those duty cycles Can you get by with less pump/injector, probably. These are just back of the envelope calculations.
    sigintel likes this.
  5. illtal
    illtal Well-Known Member
    Vehicle(s):
    Nov 16, 2018
    299
    48
    0   0   0
    Losing fuel pressure across the rails is a tell tale sign that the pump is inadequate for the amount of flow you need.
    I wouldn't mess around with not having enough fuel. At least you could probably drop in a 267 or 274 they are only like 100 bux or so at summit racing.
    TGGT likes this.
  6. Vegas5OH
    Vegas5OH Well-Known Member
    Vehicle(s):
    2016 5.0 PP
    Aug 19, 2016
    Las Vegas
    287
    170
    0   0   0
    What injectors are going to run? If you put a decent set of injectors in the car with a bap and just a drop in dw400 pump its enough to run whatever you want, e85 even. I built a 18 whipple car, 3.625 pulley with 1050x, bap and a dw400 running full e85 tuner says it still has room left in the fuel system. Return style is the preferred way though.
    Cory S likes this.
  7. moffetts
    Vehicle(s):
    Nov 30, 2015
    San Mateo CA
    821
    239
    0   0   0
    Because ultimately you are pushing the OEM fuel components way, way past what they were designed to do. Gen 3 cars do have a higher ceiling than gen 2 cars because of DI, but still, if you can justify feeding it race gas, it's not much of a stretch to be able to justify a return style system. It's a lot cheaper than having to buy a new engine because you leaned it out.
  8. OP
    SJ-KY
    First Name:
    Stephen
    Vehicle(s):
    Gt 350
    Dec 11, 2018
    Forest Hills KY
    46
    Thanks for the info gentlemen! Yes I haven’t researched factory injector size or anything so that makes since! Thought I heard with the port and direct injectors it would take you a long way but apparently I was miss informed..
  9. bluebeastsrt
    bluebeastsrt Oh boy
    First Name:
    BigD
    Vehicle(s):
    Boosted 2015 GT Premium.
    May 10, 2015
    New Jersey
    6,676
    5,514
    Rating:
    100%
    3   0   0
    Lund was comfortable tuning me out to 700 on 93 with a set of 1050 injectors and the BAP that came with the Paxton kit. They are one of the premium tuners for the coyote. If that tells you anything.
    [email protected] and Cory S like this.
  10. Mike K.
    Mike K. Well-Known Member
    First Name:
    Vehicle(s):
    2017 Mustang GTPP
    Jul 30, 2017
    Lakeland, FL
    192
    82
    0   0   0
    that’s what I was thinking also BAP and 1050x at the minimum
  11. illtal
    Vehicle(s):
    Nov 16, 2018
    299
    48
    0   0   0
    That's pretty close to the upper limits, I've seen guys get to "800" with a JMS unit but most companies don't recommend that their pumps be used on 22 volts.
    Obviously Turbo VS Supercharger, and the differences in dynos and all of that. But that's a great number as well. Hoping to get in that range too only my stock block after fuel upgrades.
  12. Andrew@Lethal
    [email protected] Well-Known Member
    First Name:
    Andrew
    Vehicle(s):
    2003 Cobra
    Feb 12, 2020
    West Palm Beach Florida
    90
    I can hook you up with a boost a pump and some 1050x injectors for your car here at @LethalPerformance! Shoot me a message if you have any questions or would like to place an order! #Teamlethal
  13. Platinum_5.0
    Platinum_5.0 Well-Known Member
    First Name:
    Daniel
    Vehicle(s):
    2017 PP GT MT82
    Jan 8, 2018
    Edmonton, Canada
    244
    72
    0   0   0
    With the 72lb injectors that came with my whipple kit I ran the 3.6 pulley on 94 pump for a year making 740whp. Car never knocked and I roll race it alot to 8000rpm every shift. No BAP and stock pump. Car did a 136MPH trap speed like that.
    Cory S likes this.
  14. lx347cd
    lx347cd Well-Known Member
    First Name:
    Tony
    Vehicle(s):
    2017 GT and 2003 Cobra
    May 10, 2019
    PA
    105
    Occupation:
    OEM Vehicle Engineer
    0   0   0
    Nice- how much boost are you seeing with that combo?
  15. Platinum_5.0
    First Name:
    Daniel
    Vehicle(s):
    2017 PP GT MT82
    Jan 8, 2018
    Edmonton, Canada
    244
    72
    0   0   0
    11.8psi with the 3.6 pulley. On the 3.5 and E85 now seeing 12.8
Loading...
Share This Page
