Made 471whp with PBD E85 tune, JLT Intake and Texas Speed headers/xpipe (catted)
Discussion in 'V8 5.0L Engine / Mods: Bolt-ons, Exhaust, Tuning' started by Sammy123, May 7, 2019.
  1. Sammy123
    Sammy123 Well-Known Member
    First Name:
    Sammy
    Vehicle(s):
    2018 Mustang GT 10 speed Auto
    Mar 14, 2019
    Orlando, FL
    236
    55
    0   0   0
    Mods on 2018 Mustang GT 10 speed:
    Palm Beach Dyno E85 tune (by Trevor Berkheiser)
    JLT CAI
    Texas Speed Headers and catted X pipe
    Got the car dyno'd today. Made 471whp with the final E85 revision I got from palm beach dyno. It then made 469whp a few minutes later.
    The 463whp number is from the initial E85 tune I got from them.
    Seems decent, but I was expecting higher. Like 490 or higher. At least according to those youtube monkeys like Stangmode and Zander.
    I attached the log files of both pulls in case anyone wants to look (Log11 of 471hp run, Log12 of 469).
    Twizzty, Kermitz and ChiTownStang26 like this.
  2. OP
    Sammy123
    First Name:
    Sammy
    Vehicle(s):
    Mar 14, 2019
    Orlando, FL
    236
    55
    0   0   0
  3. Schwerin
    Schwerin Well-Known Member
    Vehicle(s):
    2019 Mustang BULLITT
    Jan 31, 2018
    Philly
    2,003
    926
    0   0   0
    No cats you would have done a bit better. I think the others did their dynos when it was also a bit cooler out, that would help a bit. Also depends on your rear gear and tire size/weight.
    evo8904 likes this.
  4. turboluke9000
    turboluke9000 Well-Known Member
    First Name:
    Luke
    Vehicle(s):
    2018 Wrapped Base Mustang GT
    Aug 1, 2018
    Canada
    50
    49
    0   0   0
    I wouldn't think you'd hit 500whp while still having cats. Dyno numbers vary between dyno's, days, weather, basically if you so much as look at them funny. I also wouldn't trust youtube numbers very much at all.
  5. OP
    Sammy123
    First Name:
    Sammy
    Vehicle(s):
    Mar 14, 2019
    Orlando, FL
    236
    55
    0   0   0
    I don't think the high flow cats with the texas speed headers/xpipe would make that big of a difference, like I don't think it's robbing me of 30hp if I went catless. It was also a bit warm and humid, I probably should have waited for a cooler dryer day.
    I showed the logs to the tuner at PBD and they sent me another revision. I won't dyno the new revision though unless I wanna pay another $80, will wait until I do something more substantial mod wise.
    From here on out I'll just be looking at quarter mile times and trap speed.
  6. Blown86GT
    Blown86GT Well-Known Member
    Vehicle(s):
    Feb 4, 2018
    Central FL
    174
    106
    0   0   0
    Hi Sammy123...I'm just down the street in Winter Garden. Did you baseline the car with no mods?
  7. OP
    Sammy123
    First Name:
    Sammy
    Vehicle(s):
    Mar 14, 2019
    Orlando, FL
    236
    55
    0   0   0
    Unfortunately I did not. I went to Lamotta Performance to have it dyno'd. They also installed the headers and xpipe for me. Probably will stick to this shop unless you know of somewhere else that's also good?
  8. AZ18yote
    AZ18yote Well-Known Member
    First Name:
    Bryan
    Vehicle(s):
    Nov 24, 2017
    Arizona
    1,235
    409
    Occupation:
    IT Systems Engineer / Consultant
    0   0   0
    If it was a very warm day that can affect it. My 18 went 471 last time with catted ARH LTH, stock intake with drop in and AED flex tune. AZ doesn't have real e85 only flex fuel which is bout e54 at best. With the quality fuel you have I bet you are probably good for 480+ on a cooler day. I see you have the A10 you did have the pull done in 7th with all nannies off correct? And too bad you didn't baseline the car as you probably gained 50+. Seeing the before and after also helps appreciate the numbers more.
    rebellovw likes this.
  9. Myshelby3425
    Myshelby3425 Well-Known Member
    Vehicle(s):
    2018 GT
    Aug 27, 2015
    Miami
    2,136
    495
    0   0   0
    High flow catted header pick up under 10whp. The real gain is going catless or maybe upgrading to green cats which flow better but very pricey.
  10. OP
    Sammy123
    First Name:
    Sammy
    Vehicle(s):
    Mar 14, 2019
    Orlando, FL
    236
    55
    0   0   0
    Do you have a link to this comparison? All the one's I've seen show only a 3 -5 hp difference at most between high flow cats and catless, which means I might have made 475whp instead of 471whp. It's a trade off I chose. But if you're saying I would have made something like 485-490whp going from high flow to catless, I want to see which setup does this and the comparison for it.
  11. Grimace427
    Grimace427 Well-Known Member
    Vehicle(s):
    2011 Mustang 5.0
    Dec 6, 2013
    NoVA
    6,479
    1,679
    0   0   0
    The cats that come with headers barely do anything at all and don't pose much of a restriction to exhaust flow.
  12. Myshelby3425
    Vehicle(s):
    2018 GT
    Aug 27, 2015
    Miami
    2,136
    495
    0   0   0
    I’ll try digging around to find some. But there hasn’t been any FBO 500whp catted dynoes for the 2018s. Most I’ve seen are in the 470s
  13. armykyle1
    armykyle1 Well-Known Member
    Vehicle(s):
    2018 GTPP premium
    Mar 20, 2016
    Gulf Coast
    1,638
    493
    Rating:
    100%
    2   0   0
    Seems about normal for a catted setup. 480ish for catless setups too. Catless, pmas/jlt and ported mani will probably be in the 485-490 range for a auto car.
  14. 7thStreetJim
    7thStreetJim Well-Known Member
    First Name:
    Jim
    Vehicle(s):
    2018 Mustang GT Premium Shadow Black
    Jan 24, 2018
    181
    Garage Profiles:
    Occupation:
    Retired
    0   0   0
    Dyno's are supposed to compensate for DA when used properly. If you look at the bottom of the chart you see SAE 103. I believe that is the "correction factor" to give you SAE HP. The factor is supposed to be based on the Temp/Barometric pressure/humidity which are also shown (when correct).
    I would like to know where to get one of those Alcohol % testers.
  15. OP
    Sammy123
    First Name:
    Sammy
    Vehicle(s):
    Mar 14, 2019
    Orlando, FL
    236
    55
    0   0   0
    Amazon lol
    https://www.amazon.com/gp/product/B07KQNS6KD/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
Loading...
Share This Page
