Mach 1 Exhaust Pipe Sizes
Zelek
Hutto, TX
2021 Mustang Mach 1
So I have some 1-7/8" Kooks green catted headers on order and I'm looking to eliminate the bottleneck of the OEM connection to the resonator. So I'm starting with the 3" Kooks adapters
https://kooksheaders.com/exhaust/co...-connection-adapters-2015-2020-mustang-gt-50l
The next plan is to get the Stainless Bros 3" dual in/out straight through muffler/resonator:
https://www.stainlessbros.com/3-dualdual-ss304-thin-oval-muffler-17-oal--polished.html
After that, I have a few options here. I could get some 3" pipes fabricated and then reduced further down the exhaust stream to the stock pipes or reduce it at the 3" outlet side and have it welded there. I'm guessing the first option will probably be a bit more expensive.
I guess my question is what is the exhaust piping size behind the resonator? Is it 2.5" like a standard GT or is it 2.75" like a GT500?
Coastal-Mach
Wilmington, NC
Anthony
2023 BMW M440i, 2026 GMC Denali, 2021 Jeep JK
Zelek
Zelek
Hutto, TX
2021 Mustang Mach 1
WCRookie99
Illinois
G
2021 Mach 1, 2007 FR500C, 2022 LH5
WCRookie99
Illinois
G
What did you do to get rid of the check engine light?
its not on? Both O2 sensors are installed on each side and I was able to not use the harness extensions.
Now I only have two miles of testing on it and a Lund tune, maybe that’s why, I’ll let you know after I drive it some miles on the track.
Atlas1
Everett, WA
I can’t wait to hear it rip on track! You’re running stock tune right? Going to leave that alone or adjust for headers?
Zelek
Zelek
Hutto, TX
2021 Mustang Mach 1
Looks like he's on Lund. I wouldn't expect the stock tune to adjust to the full potential of adding the headers on. The CEL will usually come on if you're cruising on a highway at the same speed. Just run a couple spacers on the secondary O2's and you'll be fine if that does happen.
Zelek
Zelek
Hutto, TX
2021 Mustang Mach 1
WCRookie99
Illinois
G
So I had Lund tune to 100oct racing fuel only with LTHs as I’m only using this car for Track days. They say it’s different then their 93 Tune but didn’t say how or elaborate in any way.
Actually when reading up on the entire racing fuel difference vs pump gas, obviously the octane is higher but it’s just more pure and cleaner.
Plus, the tune is simple to convert back to stock tune in 5min or so.
I purchased Kooks axle back Muffler with 4” tips which are actually engineered to bolt the Factory Bypass actuator on them so it avoids any dashboard light or programming issues. So it 3” all the way no reduction in pipe.
if you wanted to keep the stock Axle back, Muffler and Tips, yes a 3” to 2-1/2” reducers behind the X-pipe would be needed but I don’t believe Kooks offers it standard, it would be a custom piece. (shouldn’t be that hard to fabricate)
Final comment about running spacers on the secondary O2’s. I actually did that because I didn’t like the fitting of the O2s in the Kooks pipe, so I put them in by dumb luck.
So a lot of additive reasons as to no Check Engine light.
