M-5300-W FP spring rates
CSL
WA
16 GT350
You guys comparing the force column in the Vorshlag results to the 949 results? What are impressions/rationale of the FP rears being softer combined with their differing design? I wonder if the softer FP springs are engineered to complement the presumably stiffer FP bars that were just released?
CSL
WA
16 GT350
Whomever has an educated opinion :D
Epiphany
Global
I like to disassemble things.
All I know is that I think Ford went about an inch too low with the GT350/R splitters and it screws everything up when trying to use different tire diameter/spring combinations.
mkonrad
Austin, TX
2016 GT350 Oxford White
Out of curiosity, why an inch? The tables don't to me suggest anything is falling off prematurely or acting anything other than as desired. I suppose it makes sense that the R front springs are stiffer, and the softer FP springs may have been intended as replacements for the GT350 springs rather than the R type. But I can't see anything in the data itself.
Like many people here, I picked up 30 series tires, 'R' springs, splitter and wing. So I'm looking for numbers to validate my pre-existing decisions.
CSL
WA
16 GT350
The reason I'm curious about these rates is I'm contemplating which set up I will go with for next year, and there are a few choices. My goal is to avoid lowering the car if I don't sacrifice performance. I could go with R springs and rear R bar; I could go with R springs and the new FP bars; or I could go with FP springs and bars.
My anecdotal thought is the FP bars are designed to complement their springs. At first glance it seems the R springs and FP bars are a good option to avoid lowering, but I wonder if performance will be sacrificed? With the notably different rates, particularly in the rear, I question the right option to take. Any of the tech gurus have an opinion on this?
Epiphany
Global
I'm on 30 series, R splitter in place, and both R and FR springs in boxes and ready to install either. The aero bits shouldn't be a factor that weighs as heavy in the mix as they do. The ~3/4" drop the FR springs provide really reduces ground clearance when street driving.
  • Like
Reactions: CSL
